Topic: 3 Servo, 3 buttons (Read 268 times) previous topic - next topic
Dexster
Jun 08, 2018, 12:49 am Last Edit: Jun 08, 2018, 12:52 am by Dexster
Please help. I seem to be having a issue with my code or the board, i'm not sure. I keep getting this message;
"Error compiling for board Arduino/Genuino Uno.
exit status 1
Error compiling for Arduino.Genuio Uno."
This is the code i'm using.
Code: [Select]
#include <Servo.h>
#include <Button.h>
Servo RE;
int REpos = 0;
const int buttonREPin = 2;
int buttonREState = 0;
RE.attach(9); //right eye from robotos veiw
pinMode(RE,OUTPUT);
pinMode(buttonRE,OUTPUT);
{for (REpos = 0; REpos <= 360; REpos +=1)
RE.write(REpos);
delay(59.9);
for (REpos =360; REpos >= 0; REpos -=1)
RE.write(REpos);
delay(59.9);}
buttonREState = digitalRead(buttonPin);
(buttonMOState == HIGH){
  digitalWrite(MO, HIGH);
  digitalWrite(MO, LOW);
I'm not sure why it would be doing this, could it be my code? any help on this would be much appreciated. (I understand that HIGH and LOW are for LED's, i don't know what to use to say off)
TolpuddleSartre
#1
Jun 08, 2018, 08:53 am Last Edit: Jun 08, 2018, 08:59 am by TolpuddleSartre
Look at your setup function.
Where does it end?
(It is helpful if you post error messages)
Code: [Select]
delay(59.9);
No, you need to look harder at the documentation.
Code: [Select]
(buttonMOState == HIGH){ Missing an "if", I guess.
It also looks like you've got a bunch of mismatched {} braces
vinceherman
To the point of mismatched curly braces, format your code.
CTRL-T in the development application auto formats the code, making problems with mismatched braces readily apparent.
