Loading...
Pages: [1]   Go Down
Author Topic: Uploading to Uno w/ Gentoo fails  (Read 435 times)
Offline Offline
Newbie
View Profile
I'm trying to get my Arduino Uno running with Gentoo (x86)
I installed arduino-0.21 and rxtx-2.2_pre2 from the overlay and avrdude-5.10 from portage.
The Power-LED is on, after Reset the L-Led flickers for about a second. Uno is selected in Boards, and /dev/ttyACM0 as Serial Controller.
Trying to upload the Blink-Expample I get:
Code:
Binary sketch size: 978 bytes (of a 32256 byte maximum)
/usr/share/arduino-0021/hardware/tools/avrdude -C/usr/share/arduino-0021/hardware/tools/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/build7315047689847273776.tmp/Blink.cpp.hex:i
avrdude: Version 5.10, compiled on Mar  9 2011 at 13:03:13
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino-0021/hardware/tools/avrdude.conf"
         User configuration file is "/home/robelix/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 3
         Firmware Version: 3.3
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.01s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
TX and RX Leds are flickering while the upload is running.
When trying to write manually with -F there seems to be no error - but no Blinking ;(
What is going wrong?
Robelix
Logged
Offline Offline
Newbie
View Profile
got it! - quite a hard start for a noob:
1) changed uno.upload.protocol in boards.conf from stk500 to arduino
2) hold reset, and release when upload starts
3) The Blink example does not blink. No idea why. But the BlinkWithoutDelay works.
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
I think the delay problems are caused by the version of avr-gcc you have.  For some reason, 4.5.x seems to have this issue.  You should try to use 4.3.x instead (4.3.2 or later).
Logged
Offline Offline
Newbie
View Profile
I downgraded avr-gcc from 4.5.2 to 4.3.5 and avr-libc from 1.7.0 to 1.6.2 - but still the same: the Blink-Example does not Blink.
Logged
Offline Offline
Sr. Member
View Profile
Downgrade / recompile avr-binutils to a version patched with Debian's avr-binutils patch set. (The bug seems to be in avr-ld)
Logged
Offline Offline
Newbie
View Profile
Thank you stimmer!
binutils-2.20.1-r1 instead of 2.21  - and Blink finally blinks smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
