Topic: Color Mixing Lamp values wildly fluctuating. (Read 764 times) previous topic - next topic
mikemcdonald83
Jun 10, 2018, 10:25 pm Last Edit: Jun 10, 2018, 10:29 pm by mikemcdonald83
I recently got an Arduino Starter kit and I'm working on the color mixing lamp. In the book it says that values should be pretty constant, but they're wildly fluctuating and the colors seem to be wrong. I used the sketch I wrote from the book and the one that comes in the Arduino IDE. Any idea what's going on here? The first pic is the serial print. The second is a plot with my light on, light off, and hand over sensors. The third is my breadboard. tia.
Code: [Select]
const int greenLEDPin = 9;    // LED connected to digital pin 9
const int redLEDPin = 10;     // LED connected to digital pin 10
const int blueLEDPin = 11;    // LED connected to digital pin 11
const int redSensorPin = A0;  // pin with the photoresistor with the red gel
const int greenSensorPin = A1;   // pin with the photoresistor with the green gel
const int blueSensorPin = A2;   // pin with the photoresistor with the blue gel
int redValue = 0; // value to write to the red LED
int greenValue = 0; // value to write to the green LED
int blueValue = 0; // value to write to the blue LED
int redSensorValue = 0; // variable to hold the value from the red sensor
int greenSensorValue = 0; // variable to hold the value from the green sensor
int blueSensorValue = 0; // variable to hold the value from the blue sensor
  // initialize serial communications at 9600 bps:
  // set the digital pins as outputs
  pinMode(greenLEDPin, OUTPUT);
  pinMode(redLEDPin, OUTPUT);
  pinMode(blueLEDPin, OUTPUT);
  // Read the sensors first:
  // read the value from the red-filtered photoresistor:
  redSensorValue = analogRead(redSensorPin);
  // give the ADC a moment to settle
  delay(5);
  // read the value from the green-filtered photoresistor:
  greenSensorValue = analogRead(greenSensorPin);
  delay(5);
  // read the value from the blue-filtered photoresistor:
  blueSensorValue = analogRead(blueSensorPin);
  // print out the values to the Serial Monitor
  Serial.print("raw sensor Values \t red: ");
  Serial.print(redSensorValue);
  Serial.print("\t green: ");
  Serial.print(greenSensorValue);
  Serial.print("\t Blue: ");
  Serial.println(blueSensorValue);
    In order to use the values from the sensor for the LED, you need to do some
    math. The ADC provides a 10-bit number, but analogWrite() uses 8 bits.
    You'll want to divide your sensor readings by 4 to keep them in range
    of the output.
  redValue = redSensorValue / 4;
  greenValue = greenSensorValue / 4;
  blueValue = blueSensorValue / 4;
  // print out the mapped values
  Serial.print("Mapped sensor Values \t red: ");
  Serial.print(redValue);
  Serial.print(greenValue);
  Serial.println(blueValue);
    Now that you have a usable value, it's time to PWM the LED.
  analogWrite(redLEDPin, redValue);
  analogWrite(greenLEDPin, greenValue);
  analogWrite(blueLEDPin, blueValue);
