Loading...
Pages: [1]   Go Down
Author Topic: Digital Speedometer 'layout'  (Read 990 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
im much more of a hardware nerd than software, and i plan on making a digital speedometer for my 1954 Vauxhall. im going to be taking the following general display layout from here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1293959726
and whether i missed something or not, what it uses to read the rpm and convert it to a digital readout. i intend to use a photo-interupter (the one from jaycar: ZD-1901) but what im basically here for is more to ask how i would run the code (also taken from the above link) to register the speed, the code itself is 29,000 chars
to work with the hardware layout like in this link (see the bottom pictures):
http://www.8051projects.info/forum/showthread.php/579-digital-speedometer-with-8051-Microcontroller
p.s. i would like to generate a display accurate to 0.1Km/h and i have access to hightech milling and lave equiptment too, so theres not much thats out of the question
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Placed on what. Opto devices aren't normally very good for this sort of app because of the dirt under a vehicle.
Quote
read the rpm
RPM normally refers to the engine, I assume you are talking about a wheel or tail shaft.
Quote
That's huge, I did a speedo with 6 trip meters in 7.5k (not Arduino though, raw AVR).
Quote
Just plug it in and start making changes to match your application. If you copy the hardware there shouldn't be that ,many changes to make.
Quote
I'd get something working first then look into that.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Pages: [1]   Go Up
Print
Jump to:
