Topic: Relay with DC load (Read 800 times) previous topic - next topic
dualcei
Hello,
I bought a relay module to use with my home automation project, but on the relay cover are writen only AC voltages and currents, like "10A @ 250Vac ; 15A @ 125Vac". The control are 5Vdc, ok.
I want to control a DC load (1A @ 12Vdc) with this relay module controlled by an Arduino pin (5Vdc).
Can I do this with this relay module? If connect this load (12V and 1A) at the load pins of relay it will be work normally?
Thanks a lot!
terryking228
Please point to or photo the exact relay module you have...
And, importantly, what is the load device rated at 12V 1A ??
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
dualcei
#2
Jun 14, 2018, 12:49 am Last Edit: Jun 14, 2018, 01:05 am by dualcei
Hi terryking,
The picture below describes the relay module, the DC load and what I want to do.
The load device is a 12V solenoid valve.
Can I do this circuit?
Regards!
rw950431
Yes.  240V relays will happily switch 12V  but not the other way around...
terryking228
You also need to consider the switching of a DC inductive load like that solenoid.  You need a diode (typical 1N4007 type) in reverse direction across the solenoid coil to absorb transient voltage.
See "AC vs DC: Why do I care?"  on THIS PAGE.
dualcei
Thank you rw950431 and terryking228 for the answers!
Terry,
Thanks for the link. If I understood this care is applied on loads with large current and with high inductance, like motors. My solenoid is a 1A only. But if I need to use a diode like this, can you post too a picture showing how I can put the diode on the load?
terryking228
Quote
The diagram you showed seems right.
The diode should be connected as close as possible to the solenoid terminals.
YES, you need a diode even on 'small' inductances like your solenoid.
dualcei
Hi terryking,
Ok, I understood. So I will try to get this diode. Thanks a lot!!!
Regards
