Loading...
Pages: [1]   Go Down
Author Topic: [Solved] Easy way to simultaneously deploy a sketch to multiple devices?  (Read 1455 times)
Seattle, WA
Offline Offline
God Member
View Profile
WWW
So I am working on a 2.4GHz RF project, which requires the same code on two or more nodes at once.  As it is, I compile it, and upload to one, then select the serial port for each node, and upload each one.  It'd be great to have something (even on the command line), to just say, "Send this to <all of these> ports."  Any ideas?
« Last Edit: March 14, 2011, 11:54:10 pm by maniacbug » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Hold the Shift key and click Upload.  The AVRDUDE command-line is output to the status window.  Drag the mouse to select the command-line and press Ctrl+C.  Start your favorite text editor.  Paste.  Alter the command-line as you wish.  Select the command-line and copy.  Open a command-shell.  Paste.  Repeat for the other nodes.
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Ah, thank you.  That's quite handy.  Ok, so that leads me to my next question.  Sketches seem to get built in a different temp directory every time. Is there a handy way to overcome that?  I'm comfortable with build toolchains in general, but I've not cracked open the Arduino tools one bit.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
None that I'm aware of.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Not within the IDE AFIAK.
Start using an external editor and makefile. Then you could either knock up a batch file to include the commands that CB detailed, or include a target for all the boards in the makefile.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Yah, guess it's time to buckle down and figure out the Arduino toolchain.  So far I've been really happy with the experience out of the box, content to just focus on the code.
Logged
Offline Offline
Tesla Member
View Profile
WWW
If you decide to do that I have a makefile you can use.
_____
Rob
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Yeah, that would be great.  Do you have it posted somewhere?
Logged
Offline Offline
Tesla Member
View Profile
WWW
Attached is my latest version, probably not industrial strength and still needs some cleaning up but it's been working on my system for some time.
______
Rob
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Success!  Ok, I used that make file and successfully uploaded.  w00t!
Had to tweak a few things to work on Mac OS, but not much.  And a couple tweaks to do the multiple uploads.
I think there is one bug...  This line...
Code:
CXXFLAGS = $(CDEBUG) -O$(OPT) $(CWARN) $(CXXTUNING) $(CDEFS) $(CINCS)
...should probably be using $(CXXINCS) not $(CINCS).  Otherwise, remove $(CXXINCS) up above cuz it doesn't seem to be used anywhere else.
Anyway, this is glorious!  Thanks for the help!!
« Last Edit: March 15, 2011, 12:10:49 am by maniacbug » Logged
Pages: [1]   Go Up
Print
Jump to:
