Topic: Short range radar sensors for distance measurement (Read 907 times) previous topic - next topic
SirFrederik
Hello community,
like the title suggests im looking for a radar sensor to measure short distances which I can read out using an Arduino.
I'm quite desperate as I cannot find any fitting radar sensors and thought this might be a place to ask.
Specifications:
It has to be a radar sensor, it needs to be able to measure distances continuously and it has to be as accurate as possible in a range from 0-1m (the min range cannot be higher than ~10cm). The price doesn't really matter.
I would be very thankfull for any advice/suggestion.
Greetings,
Frederik
ps: im also looking for a high quality ultrasonic sensor which outclasses the HC-SR04.
jremington
Quote
I'm quite desperate
What will happen if the sensor you want does not exist?
SirFrederik
Would be unfortunate. Is there no such sensor?
jremington
There are plenty of distance sensors that meet your range specifications.
SirFrederik
Yeah i know but it has to be a radar sensor.
el_supremo
Don't send me technical questions via Private Message.
Paul_KD7HB
Many years ago, 20-30 or more, all the automatic commercial door openers were "radar" using microwaves. Perhaps this is what the OP is looking for.
Paul
Wawa
Radar sensors for short distances are AFAIK only movement sensors.
Leo..
Paul_KD7HB
Leo..
I guess that is right. They used Doppler and that is only movement. If the OP wants to measure small distances with radar, the pulse rep rate will have to be VERY high and VERY short pulses. I doubt anything we could afford can recover from TX to RX that quickly.
I'm thinking the new automotive forward looking radar that operated in the 70 GHz band.
Paul
MorganS
Why does it have to be radar? What is it about your application that makes other sensors unsuitable? Laser and ultrasonic are more usual for that distance range.
"The problem is in the code you didn't post."
mikb55
K-band level sensors go down to 20cm.
80 GHz level sensors don't seem to publish min distance specs. Presumably you are expected to talk to the  sales engineers to discuss your requirements. You did say that price doesn't matter...
