Topic: Suggestion: Make analogwrite compatible with 8,9,10-bits PWM (Read 1 time) previous topic - next topic
lampmaker
I stumbled upon a problem when I switched to IDE 0022:
http://arduino.cc/forum/index.php/topic,55289.msg396321.html
analogWrite is now incompatible with 9 or 10-bits PWM.
suggestion is to implement multiple PWM modes (higher bit resolution, different prescalers, perhaps even different PWM modes -fast vs phase correct) in the Arduino code.
Default settings could be what it is today, but it shouldn't be too hard to implement a few switches for advanced users.
westfw
Quote
Are you on a MEGA?  The normal arduino only has one 16-bit timer; I don't see how the 8 bit timers are supposed to support 9 or 10bit PWM.
In any case, changing timer modes and expecting the predefined functions that use those timers to continue to operate correctly seems ... overly optimistic.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
