Topic: Errors opening Arduino micro schematic file in Eagle 7.1 (Read 302 times) previous topic - next topic
Billhigdon
When I try to open the eagle schematic file for the Arduino micro in Eagle 7.1 I downloaded this morning from the Arduino website I get the following error
"Error:
line 173, column 25: Unexpected ''.
The board file opens ok. it appears from a search this issue has been going on for a while.
Bill
pert
There was a report of this problem here:
https://github.com/arduino/Arduino/issues/6039#issuecomment-340795738
Quote
The dowload link for the nano files works again. Also, the cross referencing issue is indeed fixed. But still, Eagle 8 denies to open the schematic files with the following error:
and the response from the Arduino employee:
Quote
we use eagle version 7 sorry for this. We are not planning to support eagle 8 at the moment
If you've verified the problem also occurs in Eagle 7 that seems like cause to reopen that issue report. Would you mind commenting on that issue with the link to the file you downloaded and Eagle version? If you will do that I'll reopen the issue.
Note there is a fix for the problem explained further down in that thread.
