Topic: bma180 accelerometer (Read 7643 times) previous topic - next topic
Albino Cobra
Hey all,
Has anyone interfaced with this before? I found a post with alot of helpful info, like the wiring schematic, but I don't understand the code. Does any one have a simplified code or can dumb it down for me?
Thanks
liudr
Not really but I guess basic accelerometers are all the same, either analog with ratiometric output (I've got two) or digital on some sort of interface (I have two wii remote and Nunchucks but I never messed with them).
Where's the link to the codes and spec sheet?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Albino Cobra
Here is the code I found from a previous post...
#include <Wire.h>
#define address 0x40
  Wire.begin();
  initBMA180();
  delay(2000);
  readAccel();
  delay(10);
It makes a note that this code is tabbed in the IDE...
int x;
void readAccel()
  int temp, result;
  temp = 0;
  while(temp != 1)
    Wire.beginTransmission(address);
    Wire.send(0x03);
    Wire.requestFrom(address, 1);
    while(Wire.available())
   temp = Wire.receive() & 0x01;
  Wire.send(0x02);
    temp |= Wire.receive();
    temp = temp >> 2;
  Serial.print("X = ");
  Serial.println(temp);
  result = Wire.endTransmission();
void initBMA180()
  int temp, result, error;
  Wire.send(0x00);
    temp = Wire.receive();
  Serial.print("Id = ");
  checkResult(result);
  if(result > 0)
    error = 1;
  delay(10);
  if(temp == 3)
    // Connect to the ctrl_reg1 register and set the ee_w bit to enable writing.
    Wire.send(0x0D);
    Wire.send(B0001);
    if(result > 0)
   error = 1;
    delay(10);
    // Connect to the bw_tcs register and set the filtering level to 10hz.
    Wire.send(0x20);
    Wire.send(B00001000);
    if(result > 0)
   error = 1;
    delay(10);
    // Connect to the offset_lsb1 register and set the range to +- 2.
    Wire.send(0x35);
    Wire.send(B0100);
    if(result > 0)
   error = 1;
    delay(10);
  if(error == 0)
    Serial.print("BMA180 Init Successful");
void checkResult(int result)
  if(result >= 1)
    Serial.print("PROBLEM..... Result code is ");
    Serial.println(result);
    Serial.println("Read/Write success");
void readId()
  int temp, result;
  Wire.send(0x00);
  delay(10);
Seems like a lot and apparently it reads only the X axis....
scjurgen
My lib works pretty well http://www.schwietering.com/jayduino/bma180.zip. Bear in mind that you need 5 to 3.3V conversion if you use a 5V arduino.
Juergen
Albino Cobra
I have the line logic converter and the schematic for the circuit. I will check out your lib after work. Does the accelerometer output 3 values? or does it triangulate the values into a resultant? Not sure of thats a dumb question.
scjurgen
you get 3 distinct outputs (x, y, and z-axis).
z-axis will (at rest and horizontal) have 1G (or -1G if upside down), well yes, earth pulls ;) .
The library will enable you to set different settings (sensitivity, filters, using interrupts).
Juergen
WillR
And the scjurgen library works very well indeed!
Use it -- save yourself a lot of trouble.
Just another Hacker
Albino Cobra
i attached an image of a schematic that I found, is this correct? am I missing anything?
WillR
I2C hookup through level changer
Pin 1 +3.3 V (From Arduino if available)
Pin 2  GND
Pin 3  Interrupt line  I attach this directly to pin 3 On My Arduino to use the INTERRUPT Function
Pin 4  to +3.3V through a resistor -- to keep it high (1K?)
Pin 5 SCL (I2C Pin SCL Connects to Low V side of TXD Level Changer)
Pin 6  Grounded
Pin 7  SDA (I2C Pin SDA Connects to Low V Side of TXD Level Changer)
Pin 8  to +3.3V through a resistor -- to keep it high (1K?)
See the Sparkfun Schematic...
http://www.sparkfun.com/datasheets/Sensors/Accelerometer/BMA180_Breakout_v11.pdf
Code: [Select]
... code above... for other things
#include <Wire.h>
#include <bma180.h>
#include <Time.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
// Begin BMA Variables and Special Functions...
//#define DEBUGON
BMA180 bma180;
volatile byte newData=0;
volatile unsigned int countISR=0;
unsigned int served=0;
// int xval;
/*  Interrupt service
Kept simple as it really should only call the work routines...
void BMAISR(void)
  countISR++;
  //bma180.readAccel();
  newData=1;
... more code ...
The below is from setup...
// Best seetings F15HZ0 and Mode 3
  // Also F300HZ and Mode 2
  /* Filter settings
   F10HZ=0,F20HZ=1,F75HZ,F15HZ0,F300HZ,F600HZ,F1200HZ,HPPLUS1,BP300}FILTER;
  bma180.setFilter(bma180.F300HZ);
  /* G Sensitivity
   G1=0,1.G15=1,G2,G3,G4,G8,G16  ... enumerated type, 1, 1.5,2,3,4,8,16 g settings
  bma180.setGSensitivity(bma180.G15); // lets put 1.5 G maximum, not doing tests in a space shuttle
  //setRegValue(int regAdr, int val, int maskPreserve)
  /*  MODE  -- for 1, 1.5 and 2g
   0x00=LowNoise,       BW=1200 Noise 150 ug/rt
   0x01 Ultra Low Noise BW=472  Noise 150 ug/rt
   0x02 Low Noise Low Power BW= 236  Samp/Sec =1200 Noise 200 ug/rt
   0X03 Low Power       BW=600                      Noise 200 ug/rt
   Must see Page 28 section 7.7.3 for full info
  bma180.setRegValue(0x30,0x03,0xFC);
  // digital pin 3= ISR1  ---  ISR 0 = Dig Pin 2  ISR0 gave problems????
  attachInterrupt(1, BMAISR, RISING);
  // +++++++++++++++++++++++++++++++  -- note this
  // sample skipping reduces noise sonsiderably... not sure of count...
  bma180.setSMPSkip(); // allow sample skipping to reduce load...
  bma180.setISRMode(); // allow interrupt on (connect to Dig. Pin 3)
  bma180.disableWrite(); //parametrs are set so disallow further changes
  delay(2000);  //just a wait till thinggs settle and readings stabilize...
  // End BMA180 Setup +++++++++++++++++++
Just see the example Jurgen provides.
Just another Hacker
Albino Cobra
It seems the only data coming across the serial monitor is the line " Id = -1 v .FFFFCA00"
I then get nothing else...
scjurgen
Some old (working) wiring I did with an Arduino novemila used as a POC.
complete wiring with a VFD Futaba display showing values http://www.schwietering.com/jayduino/documentation/CIMG0906.JPG
and the removed BMA180 to see the wiring better http://www.schwietering.com/jayduino/documentation/CIMG0902.JPG (never mind the 3.3K resistor there, it's not connected to anything meaningful). I mounted the pins on the other side, so that in the final version the BMA180 IC would be protected against rough usage (using it in a glove).
After this worked correctly I attached the BMA180 directly to an Arduino Fio (which runs on 3.3V, so no level converter needed).
Juergen
Albino Cobra
Hmm, I wored it exactly as shown but I still get that one line. I checked all the lines for shorts and it all looks ok
scjurgen
-1 looks like a problem in the wire library. Did you initialize? Maybe post the source code (using the [code ] tags).
Juergen
Albino Cobra
Source code is from your zip files...no change
cpixip
- judging from your circuit diagram: you did not connect CS of the BMA180. As far as I know, the BMA180 will not do anything if that input is not connected to Logical HIGH - which should not exceed VIO, i.e. maximal 3.3V.
- cpixip
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
