Topic: problem fading and blinking leds simultaneously with millis (Read 2157 times) previous topic - next topic
erinbanwell
I have LED1 fading on and off with millis, and LED2 blinking with millis. There are not any delays, but when LED2 blinks ON, LED1 gets slightly dimmer, and when LED2 blinks back off, LED1 gets brighter. Is this something in my code? I suppose it could be a hardware issue, but I think it might be this code (which I borrowed from someone online).
heres my code:
Code: [Select]
#define BLINK_RATE 1000 // On/off blink every 1 second
#define FADE_RATE 6000  // Fade up and down every 2 seconds
int ledPin = 5;
int pwmPin = 10;
  pinMode(ledPin, OUTPUT);
  pinMode(pwmPin, OUTPUT);
  unsigned long time = millis();
  // Blink the LED
  if (time % BLINK_RATE > BLINK_RATE/2)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
  // Synthesize a sawtooth wave: a value from 0 to FADE_RATE/2 and back down
  long val = labs((FADE_RATE / 2) - (time % FADE_RATE));
  val = 255 * val / (FADE_RATE / 2); // convert to range 0..255..0
  analogWrite(pwmPin, val);
KirAsh4
Just tried your code on my Uno and I can't reproduce what you're seeing.  How do you have these wired up?  Are you sharing the resistor for both LEDs (the only way I was able to get what you're describing ...)
erinbanwell
oh! i actually didnt use any resistors. If I add resistors, do you think that will solve it? I'll try that and see what happens. Thanks!
Coding Badly
Quote
Doesn't matter.  If you continue to leave off current limiting resistors you will permanently damage your board.
KirAsh4
Hence my original question of how he had things wired up ...  Code is fine, but hardware is questionable ...
erinbanwell
The resistor was indeed the problem(it doesnt say "newbie" by my name for nothing). Sorry bout the hardware issue on the software forum.
This code works.
Now I'm trying to alter this code to blink sequentially through 11 LEDs while fading, instead of blinking just one LED.
My attempt gave me no blinking LEDs.
Code: [Select]
#define FADE_RATE 5000  // Fade up and down every 2 seconds
int x = 0;
int pwmPin = 10;
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
    pinMode(13, OUTPUT);
  // Blink the LED
      digitalWrite(x, HIGH);
      digitalWrite(x, LOW);
  x = x+1;
  if (x = 14)
  x = 0;
thanks again!
KirAsh4
Code: [Select]
  x = x+1;
  if (x = 14)
  x = 0;
thanks again!
You are setting the value of x to 14.  I believe you meant to compare it which means:
Code: [Select]
if (x == 14)
erinbanwell
thanks KirAsh4!
Now I'm getting all the blinking LED's blinking together instead of sequentially. Should I put it in a "for" statement? If so, where would I put it?
erinbanwell
UPDATE:
I tried using a for statement but got the same problem (all LEDs besides the fading one are blinking together instead of sequentially.
heres that code:
Code: [Select]
int x = 0;
int pwmPin = 10;
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  // Blink the LED
for (x = 0; x <= 13; x++){
  if (x == 14)
  x = 0;
KirAsh4
Actually, they're not blinking together.  However, because you're turning them on and 1ms second you're turning them off again, it appears as if they're all blinking together.  Trust me, they're not.  One simple way of testing that is to add a delay(50) before your if statement.
And by doing that, you will also discover another problem, which I will leave for you to find.
erinbanwell
thanks. I'm betting you are referring to the delay vs. millis problem, eh? Thanks again for your help!
KirAsh4
erinbanwell
what i mean is, if I add delay the fade gets all chopped up, so I need to work out a millis timer instead of delay. correct?
KirAsh4
No, the delay nor millis() has nothing to do with it getting chopped up.  Think about it for a moment.  You are using pin 10 for the fade, and you are cycling from 0 to 13 to turn LEDs on/off ...  0 to 13 ... pin 10 ... pin 10 ... 0 to 13 ...  Write it out if you don't quite see it.  Start with x == 0.  Your loop goes 0, 1, 2, 3 ... 8, 9, ??  What just happened?
KirAsh4
I'm not trying ot be a PITA here, but I don't want to just hand you the answer either.  This is how you learn (at least I do), by figuring out where my mistakes are.  In your case, just step through your loop one by one, and hopefully you'll understand why your fade on pin 10 gets all chopped up.  It's not that hard.  If you really can't tell, I'll try to explain it.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
