Topic: problem fading and blinking leds simultaneously with millis (Read 2335 times) previous topic - next topic
KirAsh4
And to further try to help you understand the problem, the delay(50) I suggested was merely to illustrate that your LEDs are in fact blinking on and off in sequence, and not all at once.  So if you remove that delay you will once again get what would appear to be a smooth fade on pin 10, however that's merely an illusion.  Because of your for loop, the fade gets interrupted every 13 cycles.
You should rethink how you're delaying the blinking and not interrupt the fade at the same time.
KirAsh4
Awesome.  Work on it a bit, and post your findings.
