Topic: Stepper motor button control  (Read 116 times) previous topic - next topic
Abelrod
looking for some help with controlling a stepper motor.
currently i am running the code below and it works fine. when i push a button the motor goes 6400 steps (1 full rev using the Big Easy Driver)
so when i push the button it executes "program"
i need the "program" to rotate 1 full rev and delay for an amount of time, repeat x# times at a button push
rotate 1 rev
stop 1 sec
rotate  1 rev
stop 1 sec
Code: [Select]
#define DISTANCE 6400
int StepCounter = 0;
int Stepping = false;
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  pinMode(3,INPUT);
  if (digitalRead(3) == LOW && Stepping == false)
    Stepping = true;
  if (Stepping == true)
    digitalWrite(9, HIGH);
    delayMicroseconds(100);
    StepCounter = StepCounter + 1;
    if (StepCounter == DISTANCE)
      StepCounter = 0;
      Stepping = false;
Robin2
#1
Jun 19, 2018, 06:15 pm Last Edit: Jun 19, 2018, 06:16 pm by Robin2
This is not very elegant but it may meet your needs and it has required very little change to your code
Code: [Select]
    runSequence = true;
  if (runSequence == true) {
    for (n = 0; n < numMoves; n++) {
        if (Stepping == false) {
            stepping = true;
            moveMotor();
    runSequence = false;
void moveMotor() {
      StepCounter = 0;
      Stepping = false;
      delay(delayPeriod);
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Abelrod
thanks a lot!
a couple of things
runSequence
moveMotor
n
are not defined?
Robin2
moveMotor() should be. Check that all the {} are properly paired.
You have to create a variable called runSequence.
And I made a mistake - this is how the line should be
Code: [Select]
for (byte n = 0; n < numMoves; n++) {
If that does not solve the problem post the actual code that you are trying to compile.
...R
