Topic: im a noob really need help for programing  (Read 568 times) previous topic - next topic
Kilian03
so im doing a project where i need to move two servos with the push of a button. when the button is pushed both of the servos should turn 90 degrees but each of them in the opposit direction. im in a real hurry and i am not able to code and this would be the only time i would need coding. the only thing i have is a arduino nano. i would appreciate if some one could do this for me or explain it to me. ive almost watched every youtube video and read  a lot  of the stuff in this forum but im not able to code it . please help
spycatcher2k
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
spycatcher2k
Nope - I can't think of anyone who will do YOUR work for free!
You can't even be bothered to try!
My price is now £100
Mrs Drew
spycatcher2k
If you want someone to write code for you, expect to pay. If you make an attempt, and need help, then that help is offered freely.
Mrs Drew
wvmarle
Can't you find a starting point (or even a near-ready sketch) in the examples that come with the Servo library?
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Kilian03
yes i manged to get e servo continius rotating 90 degrees but i dont know how to get a button involved and ow to get a second servo that turns in the opposit direction
Kilian03
#include <Servo.h>
Servo myservo;
int pos = 0;
myservo.attach(9);
for (pos = 0; pos <= 90; pos += 1) {
  // in steps of 1 degree
  myservo.write(pos);
  delay(2);
for (pos = 90; pos >= 0; pos -= 1) {
  myservo.write(pos);
  delay(10);
thats how far i got
wvmarle
Just change the angle for the other one. One goes from 0 to 90, the other from 90 to 0. Or 90-pos.
For buttons, lots of examples around as well.
Kilian03
#include <Servo.h>
Servo myservo;
int pos = 0;
  myservo.attach(9);
    myservo.write(pos);
    delay(2);
    myservo.write(pos);
    delay(10);
#include <Servo.h>
Servo myservo2;
int pos = 0;
  myservo2.attach(10);
  for (pos = 0; pos <= -90; pos += 1) {
    myservo2.write(pos);
    delay(10);
  for (pos = -90; pos >= 0; pos -= 1) {
    delay(10);
so is that correct? and about the button i saw the code online but i dont know how to build it inside my code
slipstick
It's not a good idea wasting people's time with code you haven't even bothered trying to compile. You can't have two setup() and two loop() functions in one program.
OTOH if you put the "Servo myservo2" immediately below the original one and the second .attach() in the original setup() then that would be a start. Then you can just put the myservo2.write()s immediately below the original writes with a different value...and wvmarle has already told you what that value needs to be.
But at least try compiling and testing it before you come back again.
Steve
wvmarle
... and use code tags when posting code. As explained in the sticky.
Kilian03
ok thanks steve really appreaciate that ill try what you said
Kilian03
#include <Servo.h>
Servo myservo;
Servo myservo2;
int pos = 0;
  myservo.attach(9);
    myservo.write(pos);
    delay(2);
    myservo.write(pos);
    delay(10);
  for (pos = 0; pos <= 90-; pos += 1) {
    delay(10);
  for (pos = 90-; pos >= 0; pos -= 1) {
    delay(10);
is this better now i was letting it verify but it tells me that something is wrong in the void set up function
MorganS
Use code tags,  as shown in the "how to use this forum" post.
Otherwise the forum software eats some of your code and we can't be sure what we see is exactly what you wrote.
"The problem is in the code you didn't post."
