Topic: I2C backpack 7 segment stopwatch. start pause and stop  (Read 182 times) previous topic - next topic
Ulcerdonor
Hi, This is not MY sketch. My programming abilities are quite limited, typically I can cut/paste and write the small sections to achieve my goals and learn along the way. This one is really has me stumped. Currently when it powers up, it does a little line blinky thing and waits for D2 to be grounded. Once the button is activated the stopwatch runs, another press pauses, third press resets it to 0 and forth press starts running again.
I have tried lots of experimentation to add two more buttons and nothing is working. My goal is to have one button start the stopwatch. A second button will pause the stopwatch and a third button will reset to 0.
I have tried creating buttonPins in several configurations but nothing works. Can someone please give me a hint or two?!?!?
Thanks Bryan
Code: [Select]
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
/*--Declare Matrix--*/
Adafruit_7segment matrix = Adafruit_7segment();
#define INTERRUPT_PIN 2
#define DEBOUNCE_RATE 100
volatile int timerState = 0;
volatile unsigned long debounce = 0;
volatile unsigned long startTime;
  Serial.println("Starting timer sketch..");
  /*--setup the interrupt--*/
  pinMode(INTERRUPT_PIN, OUTPUT);
  digitalWrite(INTERRUPT_PIN, HIGH);
  attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), updateTimerState, LOW);
  matrix.begin(0x70);
  matrix.clear();
  cycleZeros(250, 500);
  writeDashesToDisplay(true);
void cycleZeros(int wait, int pause) {
  for (int i = 4; i > -1; i--) {
    if (i == 2) {
      --i;
    matrix.writeDigitNum(i, 0);
    matrix.writeDisplay();
    delay(wait);
  matrix.clear();
  delay(pause);
void writeDashesToDisplay(boolean isDrawingColon){
  matrix.clear();
  matrix.writeDigitRaw(0, B01000000);
  matrix.writeDigitRaw(1, B01000000);
  matrix.writeDigitRaw(3, B01000000);
  matrix.writeDigitRaw(4, B01000000);
  matrix.drawColon(isDrawingColon);
void updateTimerState() {
  //debounce the interrupt button
  if (millis() - debounce > DEBOUNCE_RATE) {
    if (timerState == 0) {
      timerState = 1;
      /*--set the start time--*/
      startTime = millis();
    } else if (timerState == 1) {
      /*--pause the time--*/
      timerState = 2;
    } else if (timerState == 2) {
      /*--reset the time to zeros--*/
      timerState = 3;
    }else if (timerState == 3){
      /*--start the timer again--*/
      timerState = 1;
    /*--update the debounce--*/
    debounce = millis();
    Serial.print("Timer state updated! --> ");
    Serial.print(timerState);
    Serial.println("");
void writeCurrentTime() {
  unsigned long elapsedTime, seconds, minutes, msValue;
  elapsedTime = millis() - startTime;
  seconds = elapsedTime / 1000;
  matrix.drawColon(true);
  if (seconds < 10) {
    /*--pad seconds with zero--*/
    matrix.writeDigitNum(0, 0);
    matrix.writeDigitNum(1, seconds);
  } else if (seconds >= 10 && seconds < 60) {
    /*--if under 1 min. show seconds & sub-seconds--*/
    matrix.writeDigitNum(0, seconds / 10);
    matrix.writeDigitNum(1, seconds % 10);
  } else if (seconds >= 60) {
    /*--if equal or over 1 min., switch to min. & seconds--*/
    minutes = seconds / 60;
    if (minutes < 10) {
      /*--pad with zeros--*/
      matrix.writeDigitNum(1, minutes);
    } else if (minutes > 99) {
      /*--if min. exceed 99, stop timer--*/
      timerState = 2;
      return;
      matrix.writeDigitNum(0, minutes / 10);
      matrix.writeDigitNum(1, minutes % 10);
    matrix.writeDigitNum(3, (seconds % 60) / 10);
    matrix.writeDigitNum(4, (seconds % 60) % 10);
  //if less than 1 min, show milliseconds
  if (seconds < 60) {
    msValue = (elapsedTime % 1000) / 10;
    matrix.writeDigitNum(3, msValue / 10);
    matrix.writeDigitNum(4, msValue % 10);
  if(timerState == 1){
    writeCurrentTime();
  if(timerState == 3){
jremington
When in doubt, work your way through the relevant Arduino tutorials.
To understand how buttons are wired and work, one place to start is here.
