Topic: SOLVED - DMX Shield only works with Startaddress 1 ? (Read 115 times) previous topic - next topic
Endress
I have the CTC-DRA-10-R2 mounted on a Arduino UNO and i use the Conceptinetics.h library
As long as the Startadress is set to "1" everything works fine, but as soon, as i change
the startadress nothing is happening on any chanel .
Can someone help ?
EDIT:  Thanks so far, but i found the solution. The documentation says : "...is relative to the startaddress" so it must be "dmx_slave.getChannelValue (1);"
and NOT "dmx_slave.getChannelValue (startadress+1);"
