Topic: Benjamino - ATmega644 board - based on Sanguino (Read 4242 times) previous topic - next topic
NejTech
First things first, I have been experimenting with the Arduino for some time now, but I didn't post anything here. Anyway, for some reason I found making PCBs with EAGLE to be pretty addicting. So I made this. I liked the Sanguino for the unusual MCU, but there were a few factors I didn't like.
Benjamino by Jan Nejtek jr. is licensed under Creative Commons Attribution-ShareAlike 3.0 Unported License
Based on work at www.sanguino.cc and www.arduino.cc
Improvements:
  • Uses ATmega644 in SMD package
  • Has USB using FT232RL, just like in Arduino Duemilanove and Diecimila
  • Shield compatible
  • Pins marked similarly to Arduino Uno
  • Can automatically select between USB power and DC jack
  • Uses micro USB to avoid shorting out any shields.
Overall, it is a more Arduino-ish modification of Sanguino and uses the same software.
Image generated using Eagle3D.
Uploaded with ImageShack.us
Too bad I don't have a working prototype, but BatchPCB hasn't shipped it out yet. Also, if it's ever to be mass produced, I want the solder mask to be white with black silk screen.
This isn't the only thing I invented. More boards with more interesting MCU's are coming very soon.
Any ideas, suggestions? Tell me right here, right now.
graynomad
Nice board NejTek, I love the 3d render. Are the component models available in STEP format or are they proprietary Eagle.
______
Rob
NejTech
#2
Mar 15, 2011, 03:39 pm Last Edit: Mar 15, 2011, 03:42 pm by NejTech Reason: 1
Eagle3D runs as EAGLE ULP script, which processes the board into a POV-Ray file which is then rendered. Each component is a POV-Ray macro; it usually takes some fine tuning to get it rendered properly, only a few boards get rendered properly on the first try. Here and here and here is some interesting info about it.
graynomad
Thanks, I had a good read although it's not applicable to me as I don't use Eagle but I can import STEP models.
Have you considered how you're going to get your board manufactured should it come to that? Or are you happy to solder 50 of them yourself?
______
Rob
NejTech
I would either use assembly services or get a stencil, some paste and go cooking them.
