Topic: Help With Simple Countdown (Read 924 times) previous topic - next topic
gmmazar
Alright here's my problem. I have an arduino uno that I just bought and I need to have a sequence of five LED's turn on with a press of a button (first press turns on first LED, second turns on the second LED, etc). However, I also need to put in a time control where after I press the button to turn on the first LED, a timer begins to count down from one minute twenty seconds. After the time gets to one minute, I need the LED's to remain in their current state whether it be on or off, and then after an additional twenty seconds they turn off. So far, I have the LED's working, but I've spent hours trying to find some way to start a countdown with no progress whatsoever  :0 . Please help.
johnwasser
You have a 1:20 time interval.  The timer starts when you press the button.  You track the number of button presses for the first 20 seconds.  You display that number for 20 seconds, then you turn off the LED's for the remaining 40 seconds?
State 0:  All LED's are off.  No buttons are pressed.  Timer is not running.
    On button press, Start timer, increment number of lights, got to State 1
State 1: Some number of LED's are lit and timer is running.
    On button press, increment number of lights.
    On timer reaches 20 seconds (1:20->1:00):  Re-start timer. Go to State 2
State 2: Some number of LED's are lit and timer is running.
    On timer reaches 20 seconds (1:00->0:40): Turn off all LED's. Re-start timer.  Go to State 3
State 3: Lights are off.  Timer is running.
    On timer reaches 40 seconds (0:40->0:00):  Go to State 0
Normally one 'starts a timer' by taking note of the current value of millis() (number of milliseconds since the Arduino started) and then checks for millis() >= (start_time + millisecondsToWait.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Graynomad
#2
Mar 15, 2011, 04:59 pm Last Edit: Mar 15, 2011, 05:00 pm by Graynomad Reason: 1
When the first button is pressed you save the time
unsigned long start_time = millis();
then somewhere in your existing loop that checks the buttons you check that time
if (millis() - start_time > 1000 * 60) {
   // set a flag that stops any further button-pressing action
if (millis() - start_time > 1000 * 80) {
   // turn all LEDs off
That's the gist of it. See if you can incorporate that into your existing code.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
