Topic: When using tcpReply (), more than 512 bytes can not be received. (Read 135 times) previous topic - next topic
Jungsu
#include <EtherCard.h>
byte Ethernet::buffer[700];
const char* reply = ether.tcpReply(session);
  if (reply != 0) {
    Serial.println(reply);
I use the above routine. Only 512 bytes are received. I need a maximum of 560 bytes. What should I do?
PaulS
Quote
What should I do?
Two possibilities.
1) Get realistic. You have a certain amount of memory available. You can't use more than that.
2) Look at the source code, to see where the 512 byte limitation comes from. A TCP packet size is 512 bytes. Coincidence? Probably not.
