Loading...
Pages: [1]   Go Down
Author Topic: Calling Functions NOT working as expected...  (Read 301 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
OK, full disclosure: I orig. posted this in the Motors & Controllers section, thinking I was having an issue with my hardware.
I have since decided that this is not the case. First, the code:
Code:
// Motor Controls
const int PWMELPin = 10; // Enable PWM Left Motor
const int PWMERPin = 11; // Enable PWM Right Motor
const int L1Pin = 2; // L1 = Left Motor Lead 1
const int L2Pin = 3; // L2 = Left Motor Lead 2
const int L3Pin = 4; // L3 = Right Motor Lead 1
const int L4Pin = 5; // L4 = Right Motor Lead 2
const int LEDxPin = 12; // LEDx
const int LEDPin = 13; // LED
const int Duration = 1000;
    pinMode(PWMELPin, OUTPUT);
    pinMode(PWMERPin, OUTPUT);
    pinMode(L1Pin, OUTPUT);
    pinMode(L2Pin, OUTPUT);
    pinMode(L3Pin, OUTPUT);
    pinMode(L4Pin, OUTPUT);
    pinMode(LEDPin, OUTPUT);
    pinMode(LEDxPin, OUTPUT);    }
//Main Loop
    while (true)
        MotorL(0, 1);
        MotorR(0, 1);
        digitalWrite(LEDPin, LOW);
        delay(Duration);
        MotorL(1, 1);
        MotorR(1, 1);
        digitalWrite(LEDPin, HIGH);
        delay(Duration);
        MotorL(0, 0);
        MotorR(0, 0);
        delay(Duration);
        MotorL(1, 0);
        MotorR(1, 0);
        delay(Duration);
        continue;
// Motor Driver Routines**************************************************
// (Direction, Speed)
// Direction
// 1=Forward
// 0= Reverse
// Speed
// 1 = High/250
// 0 = Low/50
void MotorL(int Direction, int Speed)
    // Left Motor
    if (Speed = 1)
        analogWrite(PWMELPin, 250);
        analogWrite(PWMELPin, 50);
    if (Direction = 1)
        digitalWrite(LEDxPin, HIGH);
        digitalWrite(L1Pin, HIGH);
        digitalWrite(L2Pin, LOW);
        digitalWrite(LEDxPin, LOW);
        digitalWrite(L1Pin, LOW);
        digitalWrite(L2Pin, HIGH);
void MotorR(int Direction, int Speed)
    // Left Motor
    if (Speed = 1)
        analogWrite(PWMERPin, 250);
        analogWrite(PWMERPin, 50);
    if (Direction = 1)
        digitalWrite(L3Pin, HIGH);
        digitalWrite(L4Pin, LOW);
        digitalWrite(L3Pin, LOW);
        digitalWrite(L4Pin, HIGH);
Here's the problem. Running this code does NOT produce the expected results.
I took L1, L2, L3, L3, PWMEL, and PWMER to LEDS to check...
When I run this, L1, L3, PWMEL,PWMER, and LEDx turn on and STAY on
L2, L3 never so much as flicker
LED (Pin 13) Blinks on and off, like clockwork
This tells me that, Although the main loop is running (13 flashing), the 2 Motor
Driver Functions are NOT working as intended.
I am assuming that I am doing something BASIC wrong, but I don't see it....
Help?!?!
Edit to add...
I am using the following, in general, to call the motor functions...
        MotorL(0, 1);
Is passing an int "pure" (Not assigned to a variable) permitted?
« Last Edit: March 15, 2011, 11:44:11 am by Everseeker » Logged
UK
Offline Offline
Full Member
Kittens eat Arduinos
View Profile
I dont see anything wrong with your code...
try replacing loop() with
Code:
int i ;
  for (i=2; i<=5; i++)
    digitialWrite(i, HIGH) ;
    delay(1000) ;
    digitalWrite(i, LOW) ;
  for (i=10; i<=13; i++)
    delay(1000) ;
This treats all the pins alike.
Any differences in behaviour is then down to wiring.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Done.
all the LED's blinked once...
Wires are fine.
(I had the same thought... Ran a "Cylon" script smiley but I ran yours, just in case...)
Logged
New Hampshire
Offline Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
View Profile
WWW
direction = 1 is an assignment, not a comparison.  direction == 1 is a comparison.
So:
Code:
if (direction = 1)
will always evaluate to true, as you are assigning 1 to direction
What you want is
Code:
if (direction == 1)
You have the same error with your speed comparisons as well.
On a separate note, your while(true) is accomplishing nothing.  There's no point in having that code block.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Oh god... == is not the same as =
I KNOW that... I am not an idiot... I would never make that kind of mistaaaa...ummm.... errrr.....
oops
I guess I did... silly me smiley
Thanks for that... will solve my problems smiley
The
While (True){
//stuff
construct was just a way to put the thing in an endless loop...
Logged
New Hampshire
Offline Offline
God Member
View Profile
WWW
The loop() function is an endless loop.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Point taken.
Whenever I want something to sit and loop, I reflexively use a while true construct.
but yeah, I guess that's not needed in this case smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
