Loading...
Pages: [1]   Go Down
Author Topic: ds18b20  (Read 434 times)
Offline Offline
Newbie
View Profile
Hi!
I am making a new thermometer with LCD display and communication to computer. And I was wandering if you can help me. I took some parts of the code from arduino pages, made some edits in it and uploaded on my processor (ATmega328). But there have to be some problem. It measures temperature but not correctly. It's about 2 degree of celsius. Why it's about 2 degrees? Because i measure temperature in my room. On arduino says 23,62 °C on mercury thermometer says about 21,5 °C let say 21,62. Can you please take a look on my code? I simply don't know what am I doing wrong. I am using external powering of ds18b20, there is 4k7 ohm resistor on the bus. I know that I can simply take the temperature down by mathematics. But i want to understand the problem. Thanks everyone for your time.
There is my code:
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10);  // on pin 10
void setup(void) {
  // initialize inputs/outputs
  // start serial port
void loop(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
  float temp;
  if ( !ds.search(addr)) {
    ds.reset_search();
    return ;
  for( i = 0; i < 8; i++) {
  if ( OneWire::crc8( addr, 7) != addr[7]) {
    return ;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);                             // Read Scratchpad
  for ( i = 0; i < 9; i++) {                  // we need 9 bytes
    data = ds.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << smiley-cool + LowByte;
  SignBit = TReading & 0x8000;                // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1;      // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Whole = Tc_100 / 100;                      // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  temp = ((data[1] << smiley-cool + data[0])*0.0625;
  if (SignBit) // If its negative
    Serial.print("-");
  Serial.print("Teplota: ");
  Serial.print(Whole);
  Serial.print(".");
  if (Fract < 10)
    Serial.print("0");
  Serial.print(Fract);
  Serial.print(" Temp --> ");
  Serial.print(temp);
  Serial.print("\n");
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
Look at the Mile Burton stuff.
http://download.milesburton.com/Arduino/MaximTemperature/DallasTemperature_360.zip
Saves a lot of time.
Logged
Just another Hacker
0
Online Online
Tesla Member
Arduino rocks
View Profile
Mecury thermometers can be wrong!  Measure the temperature of melting ice if you want to callibrate it.
Logged
Offline Offline
Newbie
View Profile
Thanks for your advice. It measures correctly...thank you;-)
Logged
Pages: [1]   Go Up
Print
Jump to:
