Topic: BOMB CODE then Timer URGENT (Read 501 times) previous topic - next topic
kdawk
HI guys I'm trying to make a prob bomb game. It should start with a keypad password. after the right password then there is a timer that counts down while you play a jumper wire game. which act as just buttons i guess. For the life of me I can't get it figured. I require URGENT help. PLEASE HELP !
CODE:
#include <Keypad.h>
#include <Wire.h>
#define Password_Length 9
int seconds = 15; // count seconds
int minutes = 1; // count minutes
int hours = 0; // count hours
char Data[Password_Length];
char Master[Password_Length] = "20134030";
byte data_count = 0, master_count = 0;
bool Pass_is_good;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {3, 4, 5, 6};
byte colPins[COLS] = {7, 8, 9};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x3F, 20, 4);
  lcd.init();                      // initialize the lcd
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.begin(20, 4); //set up the LCD's number of columns and rows
  // declare pin 9 to be an output:
  digitalWrite(23, HIGH);
  pinMode(14, INPUT_PULLUP);
  pinMode(15, INPUT_PULLUP);
  pinMode(16, INPUT_PULLUP);
  pinMode(17, INPUT_PULLUP);
  pinMode(18, INPUT_PULLUP);
  pinMode(A0, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(A1, OUTPUT);
void clearData() {
  while (data_count != 0) {
    Data[data_count--] = 0;
void stepDown() {
  if (seconds > 0) {
    seconds -= 1;
    if (minutes > 0) {
      seconds = 59;
      minutes -= 1;
void Socket()
  if (digitalRead(14) == LOW)
    digitalWrite(A0, HIGH);
    digitalWrite(A0, LOW);
  if (digitalRead(15) == LOW)
    digitalWrite(10, HIGH);
    digitalWrite(10, LOW);
  if (digitalRead(16) == LOW )
    digitalWrite(12, HIGH);
    digitalWrite(12, LOW);
  if ( digitalRead(17) == LOW)
    digitalWrite(11, HIGH);
    digitalWrite(11, LOW);
  if (digitalRead(18) == LOW && digitalRead(17) == LOW && digitalRead(16) == LOW &&
      digitalRead(14) == LOW && digitalRead(15) == LOW)
    digitalWrite(A1, HIGH);
    digitalWrite(13, HIGH);
    lcd.noDisplay();
    delay(7000);
  digitalWrite(2, HIGH);
void Timer() {
  lcd.begin(20, 4);
  lcd.print("DETONATION IN: ");
  // lcd.scrollDisplayLeft();
  // wait a bit:
  delay(2000);
  while (minutes > 0 || seconds > 0) {
    lcd.setCursor(4, 2);
    (minutes < 10) ? lcd.print("0") : NULL;
    lcd.print(minutes);
    lcd.print(":");
    (seconds < 10) ? lcd.print("0") : NULL;
    lcd.print(seconds);
    lcd.display();
    stepDown();
    lcd.noDisplay();
    delay(7000);
  while (minutes == 0 && seconds == 0)
  { lcd.clear();
    lcd.print("   BOMB DETONATED");
    delay(1500);
  lcd.setCursor(0, 0);
  lcd.print("Enter Password:");
  customKey = customKeypad.getKey();
  if (customKey == '*')
  { lcd.clear();
    clearData();
    lcd.setCursor(0, 1);
  if (customKey >= '0' && customKey <= '9') {
    Data[data_count] = customKey;
    lcd.setCursor(data_count, 1);
    lcd.print(Data[data_count]);
    data_count++;
  if (data_count == Password_Length - 1) {
    lcd.clear();
    if (!strcmp(Data, Master)) {
      Timer();
    else {
      lcd.print("Incorrect");
      delay(1500);
    lcd.clear();
    clearData();
Help Me out please
Excuse me. I know your message was urgent, but I only saw it today, searching for the Arduino Due.
There is at least one bug in your code. You are using a 4x4 Keypad, but at the time of creating the Array for the columns, you used only 3 pins.
Code: [Select]
byte colPins[COLS] = {7, 8, 9}; //// <<<<<< This is what I am talking about.... You need one more pin.
have you seen this here:
https://nootropicdesign.com/gametimerpro/
Or this:
https://www.instructables.com/id/Arduino-defuseable-bomb-perfect-for-airsoft-games-/
I hope it helps.
