Topic: sdFat does not name a type (Read 924 times) previous topic - next topic
AHETEKU
thanks a lot guys am most grateful
but there is another problem after correcting wprogram.h
the problem now is sdFat does not name a type and below is the erroe and my code please help me out
Arduino: 1.8.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
In file included from C:\Users\STEADF~1\AppData\Local\Temp\arduino_modified_sketch_345838\sketch_jun23b.ino:20:0:
C:\Program Files (x86)\Arduino\libraries\SdFat/SdFat.h:283:8: error: conflicting return type specified for 'virtual void SdFile::write(uint8_t)'
   void write(uint8_t b);
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232,
                 from sketch\sketch_jun23b.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:51:20: error:   overriding 'virtual size_t Print::write(uint8_t)'
     virtual size_t write(uint8_t) = 0;
sketch_jun23b:23: error: 'SdFat' does not name a type
 SdFat sd;
C:\Users\STEADF~1\AppData\Local\Temp\arduino_modified_sketch_345838\sketch_jun23b.ino: In function 'void setup()':
sketch_jun23b:45: error: 'sd' was not declared in this scope
   if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
C:\Users\STEADF~1\AppData\Local\Temp\arduino_modified_sketch_345838\sketch_jun23b.ino: In function 'void loop()':
sketch_jun23b:62: error: 'O_AT_END' was not declared in this scope
     if (!myFile.open(photoTitle, O_RDWR | O_CREAT | O_AT_END)) {
sketch_jun23b:63: error: 'sd' was not declared in this scope
       sd.errorHalt("opening photoTitle.txt for write failed");
exit status 1
option enabled in File -> Preferences.
PIR Motion Detection - Camera Capture
by Jennifer Case
5/21/2013
Parts:
-PIR Sensor
-SD Card Breakout Board
-TTL Camera
Pin 2,3 - Camera
Pin 8 - PIR Sensor
Pin 10 - CS/D3
Pin 11 - CMD
Pin 12 - D0
Pin 13 - CLK
#include <SoftwareSerial.h>
#include <SdFat.h>
//SD Card
SdFat sd;
SdFile myFile;
int picCnt = 0;
//Camera
byte incomingbyte;
SoftwareSerial cameraSerial = SoftwareSerial(2, 3);   //Configure pin 2 and 3 as soft serial port
int a=0x0000,j=0,k=0,count=0;   //Read Starting address
uint8_t MH,ML;
boolean EndFlag=0;
//Declare pins
const int chipSelect = 10;
int pirPin = 8;
  Serial.begin(19200); //start serial
  cameraSerial.begin(38400); //start serial with camera
  // Initialize SdFat or print a detailed error message and halt
  // Use half speed like the native library.
  // change to SPI_FULL_SPEED for more performance.
  SendResetCmd(); //allows camera to take pictures
  delay(3000); //delay necessary for camera reset
  int val = digitalRead(pirPin); //read from PIR sensor
  //when val is HIGH, there is motion -> take pictures
  if (val == HIGH) {
    //create title for images
    char photoTitle[25] = {};
    sprintf(photoTitle, "pic%d.txt", picCnt);
    //Serial.println(photoTitle);
    //make sure file can be created, otherwise print error
    //Serial.print("Writing to file...");
    SendTakePhotoCmd(); //take photo
    delay(200); //delay to make sure there is no drop in the data
    //Serial.println("Start pic");
    while(cameraSerial.available()>0) {
      incomingbyte=cameraSerial.read(); //clear unneccessary serial from camera
    byte b[32];
    while(!EndFlag) {
      j=0;
      k=0;
      count=0;
      SendReadDataCmd(); //command to get picture from camera
      delay(75); //delay necessary for data not to be lost
        incomingbyte=cameraSerial.read(); //read serial from camera
        k++;
        if((k>5)&&(j<32)&&(!EndFlag)) {
          b[j]=incomingbyte;
          if((b[j-1]==0xFF)&&(b[j]==0xD9))
          EndFlag=1; //when end of picture appears, stop reading data
          j++;
          count++;
      for(j=0;j<count;j++) { //store picture into file
        if(b[j]<0x10)
          myFile.print("0");
        myFile.print(b[j], HEX);
      myFile.println();
    StopTakePhotoCmd(); //stop this picture so another one can be taken
    EndFlag = 0; // reset flag to allow another picture to be read
    //Serial.println("End of pic");
    myFile.close(); //close file
    //Serial.println("done.");
    //Serial.println();
    picCnt++; //increment value for next picture
//Send Reset command
void SendResetCmd() {
  cameraSerial.write((byte)0x56);
  cameraSerial.write((byte)0x00);
  cameraSerial.write((byte)0x26);
//Send take picture command
void SendTakePhotoCmd() {
  cameraSerial.write((byte)0x36);
  cameraSerial.write((byte)0x01);
  a = 0x0000; //reset so that another picture can taken
void FrameSize() {
  cameraSerial.write((byte)0x34);
//Read data
void SendReadDataCmd() {
  MH=a/0x100;
  ML=a%0x100;
  cameraSerial.write((byte)0x32);
  cameraSerial.write((byte)0x0c);
  cameraSerial.write((byte)0x0a);
  cameraSerial.write((byte)MH);
  cameraSerial.write((byte)ML);
  cameraSerial.write((byte)0x20);
  a+=0x20;
void StopTakePhotoCmd() {
  cameraSerial.write((byte)0x03);
Delta_G
It looks like you haven't taken time to read the "How to use this forum - please read" post at the top of every board.  Please take a moment to review that.  It explains among other things how to properly post code.
It looks like you are getting code from some ancient source.  Perhaps the best thing for you to do would be to find a source of newer code for what you want to do.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
sterretje
I've copied your code from reply #5 (please modify your reply to include code tags), installed the SdFat library using the library manger and it happily compiled (IDE 1.8.5).
There are some warnings relating to SoftwareSerial, but no errors.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
AHETEKU
#7 please send me your e-mail address
this is mine aheteku@gmail.com
i have installed the sdfat library but still please
Coding Badly
@AHETEKU, stop cross-posting.  Two threads trashed.
AHETEKU
#5
Jun 23, 2018, 06:55 pm Last Edit: Jun 23, 2018, 07:22 pm by AHETEKU Reason: typing error
please am having the same problem here
error compilling for board arduino/genuino uno
please some one should help me out below is my code n error please
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:22:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorHalt(Print* pr) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: In function 'void errorHalt(Print*)':
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:23:16: error: 'errorPrint' was not declared in this scope
errorPrint(pr);
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: At global scope:
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:27:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorHalt(Print* pr, char const* msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: In function 'void errorHalt(Print*, const char*)':
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:28:21: error: 'errorPrint' was not declared in this scope
errorPrint(pr, msg);
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:32:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorPrint(Print* pr) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: In function 'void errorPrint(Print*)':
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:33:22: error: 'cardErrorCode' was not declared in this scope
if (!cardErrorCode()) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:37:27: error: 'cardErrorCode' was not declared in this scope
pr->print(cardErrorCode(), HEX);
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:39:29: error: 'cardErrorData' was not declared in this scope
pr->println(cardErrorData(), HEX);
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:42:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorPrint(Print* pr, char const* msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:48:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorHalt(Print* pr) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: In function 'void initErrorHalt(Print*)':
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:49:20: error: 'initErrorPrint' was not declared in this scope
initErrorPrint(pr);
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:53:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorHalt(Print* pr, char const *msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:58:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorPrint(Print* pr) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp: In function 'void initErrorPrint(Print*)':
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:59:21: error: 'cardErrorCode' was not declared in this scope
if (cardErrorCode()) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:65:18: error: 'vol' was not declared in this scope
} else if (vol()->fatType() == 0) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:67:19: error: 'vwd' was not declared in this scope
} else if (!vwd()->isOpen()) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:74:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorPrint(Print* pr, char const *msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:80:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorPrint(Print* pr, const __FlashStringHelper* msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:86:6: error: 'SdFatBase' has not been declared
void SdFatBase::errorHalt(Print* pr, const __FlashStringHelper* msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:91:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorHalt(Print* pr, const __FlashStringHelper* msg) {
C:\Program Files (x86)\Arduino\libraries\SdFat\src\SdFat.cpp:96:6: error: 'SdFatBase' has not been declared
void SdFatBase::initErrorPrint(Print* pr, const __FlashStringHelper* msg) {
exit status 1
Error compiling for board Arduino/Genuino Uno.
AHETEKU
#6
Jun 23, 2018, 07:05 pm Last Edit: Jul 19, 2018, 10:28 pm by Coding Badly
this is the code
Code: [Select]
Parts:
-PIR Sensor
-TTL Camera
Pin 2,3 - Camera
Pin 8 - PIR Sensor
Pin 10 - CS/D3
Pin 11 - CMD
Pin 12 - D0
Pin 13 - CLK
#include <SdFat.h>
//SD Card
SdFat sd;
SdFile myFile;
int picCnt = 0;
//Camera
byte incomingbyte;
uint8_t MH,ML;
boolean EndFlag=0;
//Declare pins
int pirPin = 8;
if (val == HIGH) {
byte b[32];
while(!EndFlag) {
 j=0;
 k=0;
 count=0;
   k++;
     b[j]=incomingbyte;
     j++;
     count++;
   if(b[j]<0x10)
     myFile.print("0");
 myFile.println();
//Serial.println();
void FrameSize() {
//Read data
MH=a/0x100;
ML=a%0x100;
a+=0x20;
Moderator edit: [code] [/code] tags added.
AHETEKU
AHETEKU
please am very sorry for any inconvenience please forgive me
by the way thanks for the corrections
the probelm am having now is error  compilling board arduino/genuino uno
  errorPrint(pr);
  initErrorPrint(pr);
exit status 1
UKHeliBob
I am sure that it will be of no consolation to you but it compiles OK for me
Code: [Select]
Sketch uses 14120 bytes (45%) of program storage space. Maximum is 30720 bytes.
Global variables use 1020 bytes (49%) of dynamic memory, leaving 1028 bytes for local variables. Maximum is 2048 bytes.
IDE 1.8.5
Win 10
Nano board
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
sterretje
AHETEKU posted the same question a few days ago and the then code also compiled for me.
ChrisTenone
This suggests the problem lies in the installation. Sounds like the libraries may be corrupted, or in the wrong place.
What, I need to say something else too?
AHETEKU
kk thanks very much
but am still having the same problem
am using windows 8.1 and arduino version 1.8.5
i dont know what to do now
AHETEKU
kk thanks very much
Delta_G
Maybe it would be smart to post this on a thread that doesn't say "SOLVED" in the title so people don't think that the problem is already solved and then they read.
Maybe it would be a good idea to read the posting guidelines I keep trying to point you to and post your code properly so more people will be willing to help.
Those seem like to smart options to me.
|| | ||| | || | ||  ~Woodstock
