Topic: Preventing parasitic power; how? (Read 278 times) previous topic - next topic
sterretje
Hi all,
this is a theoretical question that was triggered by another thread.
If the power to a LCD is removed, it might very well still be powered via a microcontroller's output pins.
I could think of two solutions to prevent the parasitic powering, but I'm not sure if they are correct.
1)
First thought was to use a bus driver like a 74HC244 and tristate the outputs before powering off the LCD
2)
Thinking about (1), thought came up to set all data and control pins on the microcontroller to input (high impedance).
I think that both will work but like to know if I missed something or if there are implications using those approaches.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ChrisTenone
The rule on IC components such as op amps, is to not power any input high if the chip itself is not powered. Same goes for a board level component, I'd say. So yout (2) answer seems to satisfy this.
What, I need to say something else too?
Grumpy_Mike
An other soloution is to use opto isolators on persistent inputs.
sterretje
Thanks all for the replies.
How many optocouplers in a package? I'm only aware (if not mistaken) of dual ones but haven't looked at those for ages.
septillion
Or by adding resistors in a way the current is limited enough :) Couple of 100k's will probably do it.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
wvmarle
Commonly available in packages of 1, 2, 3 and 4 (e.g. the PC817, PC827, PC837 and PC847).
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
