Topic: 8x Relay board question (Read 270 times) previous topic - next topic
woujer
Hey i always read in about the neutral screw on a relayboard and a daisy chain connection with eachother.
i'm not to familliar with relays and would like some help and explanation about these things.
Thank you!
sterretje
A link to what you've read might help us to understand what you're talking about.
To explain a relay, see it as a switch that can be controlled by something else.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
woujer
This is the text i'm talking about i don't don't understand what the neutral screw is on the relay.
Once adjusted, unplug your power supply. Solder wires to the positive output terminals of the buck converters used to power the pumps, leaving the negative terminals for later. For me this was the 6 and 12 volt buck converters. The length will vary depending how you may wish to lay out the electronics, but 6-12 inches (15-30 cm) should be good. These wires will be attached to the neutral screw terminals on the relay board. Make any relays that will be switching the same voltage adjacent to each other, and daisy chain their neutral terminals together. Make sure the wire you are using can withstand the current it will be subjected to. The relays and pumps will be connected later in the Assembly step.
outsider
Sounds like the amateur author is using "neutral" in the same context as "ground, 0 Volts, circuit common," etc. Can you post a link to that text?
woujer
http://www.instructables.com/id/Robotic-Bartender-Arduino-Based/
woujer
Does he mean with neutral screw the common ?
