Topic: Arduino as ISP Error (Read 1 time) previous topic - next topic
landru
I'm using (or trying to, at least) an Arduino Pro mini 5v 16mhz (atmega328P)to program the bootloader on a atmega 328.
I have the (to be programmed) chip with a 16mhz crystal and supporting hardware.
I've uploaded the ArduinoISP to the pro mini, and put the 120ohm resistor to bypass the auto reset. I have the board setting to program a 5v 16mhz pro mini.
Now, when I try to burn the bootloader with arduino as ISP i get an error:
Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Any ideas? I've already double checked the wiring.
Thanks
spycatcher2k
Have you selected :
Arduino Duemilanove or Nano w/ ATmega328
in the boards menu?
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
landru
Yes, I've tried that. It gives me lots of errors.
spycatcher2k
can u post a photo of your setup plz, and try to show your wireing if poss.
(include the usb programmer setup if poss.)
