Loading...
Pages: [1] 2   Go Down
Author Topic: Arduino UNO + Pololu USB AVR Programmer : issues  (Read 2091 times)
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I want to burn the bootloader in a blank Atmega328. I use the Pololu programmer, connecting the ICSP plug directly to Arduino, battery-powered.
I adjusted the two configuration files in this way (I'm under Windows XP):
##Add this to the top of the boards.txt file.
board328p.name=Boarduino
board328p.upload.using=avrispv2
board328p.upload.maximum_size=32768
board328p.build.mcu=atmega328p
board328p.build.f_cpu=16000000L
board328p.build.core=arduino
##Add this to the bottom of the programmers.txt file.
avrispv2.name=AVR ISP v2
avrispv2.communication=serial
avrispv2.protocol=avrispv2
I open the program the Arduino, and select:
Arduino UNO
com port -> Pololu COM port (there are 2)
Programmer -> AVR ISP v2
I get only errors. I tried using both the COM, I tried to use Boarduino instead of Arduino.
Nothing to do. Please help me!
Thank you all!
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Open Device Manager.  Open the Ports node.  There should be two entries for the Pololu programmer...
Pololu USB AVR Programmer Programming Port (COM?)
Pololu USB AVR Programmer TTL Serial Port (COM?)
Which serial port is in parenthesis after the "Programming Port"?
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
12 and 13!!
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I have this configuration:
Uploaded with ImageShack.us
To program the bootloader I try to use COM number 12, but I get this error:
« Last Edit: March 17, 2011, 04:49:37 am by GianfrancoPa » Logged
Gianfranco
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I changeg COM number to 5 and 6 in order to use the programmer under AVR STUDIO, but it cant recognize the programmer...
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
COM12 is the correct choice.
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I changed 12 to 5 because avr studio can accepts COM port untill 9
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Did you install the device driver...
http://www.pololu.com/docs/0J36/all#3
Does the configuration utility work...
http://www.pololu.com/docs/0J36/all#3.d
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I know the manual very well smiley-grin
But you use the programmer with Arduino software? Or you use AVRDUDE ?
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Yes.
Quote
Sometimes.
Logged
Portugal
Offline Offline
God Member
View Profile
Arduino IDE uses the avrdude it just hides that from the user...
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I know it, but I have to exclude, if possible, that the programmer is broken...
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Have you tried using the configuration utility?
Have you tried a different USB cable?
Are you certain you have the six-pin cable correctly connected?
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
Yes, it recognizes the programmer
Quote
Yes, I get the same issues!
Quote
The controller has a yellow LED that flashes when it receives from 5V Vcc (more or less). when the Arduino is running normally, the reset pin has a voltage of 5V, but when I press the reset button, this pin indicates 0V.
When I plug in the 6-pin connector, I press the reset button, if the LED
yellow is still blinking, it means it is connected properly. however, if not blinking, it means that I have reversed the sense of connection!
is wrong?
Logged
Gianfranco
Pages: [1] 2   Go Up
Print
Jump to:
