Loading...
Pages: 1 [2]   Go Down
Author Topic: Arduino UNO + Pololu USB AVR Programmer : issues  (Read 1989 times)
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Sounds like it is working just like mine does.  Try this from the command-line...
avrdude -v -v -v -patmega328 -cavrispv2 -P\\.\COM5
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
Under AVRDUDE, no?
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
Under AVRDUDE, no?
I don't understand.
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I have to launch this command line using AVRDUDE, not Arduino software, isn't it?
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Yes.  You type the command (or copy-and-paste it) into a "dos prompt" (a command-shell).  The command shell can be started by running "CMD".
You will either have to navigate to the folder containing AVRDUDE or modify the PATH.  These update the PATH on my computer so I can run AVRDUDE...
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\utils\bin
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\bin
set PATH=%PATH%;C:\arduino\arduino-0022\hardware\tools\avr\etc
Replace "C:\Arduino\arduino-0022\" with the Arduino root folder on your computer.
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
Under AVRDUDE, no?
This line don't functions, I modified it so:
Code:
avrdude -v -v -v -patmega328p -cavrispv2 -P\\.\COM5
and I get:
Quote
C:\Documents and Settings\Gianfranco>avrdude -v -v -v -patmega328p -cavrispv2 -P
\\.\COM5
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : avrispv2
avrdude: ser_send(): write error: sorry no info avail
Logged
Gianfranco
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
http://forum.pololu.com/viewtopic.php?t=2398
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I'm using windows XP SP3...
I opened a thread on pololu forum: http://forum.pololu.com/viewtopic.php?f=3&t=3722&p=17560#p17560
Logged
Gianfranco
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I've installed the programmer in a different pc, and it function!!
Logged
Gianfranco
Offline Offline
Jr. Member
View Profile
The post in Reply #4 says that the programmer port is assigned to COM12.  The command line in Reply #15 is directing to COM5.  Avrdude will not be able to find the programmer at COM5.
Logged
Palermo
Offline Offline
God Member
Arduino rocks
View Profile
I've changed com port from 12 to 5
Logged
Gianfranco
Pages: 1 [2]   Go Up
Print
Jump to:
