Topic: Arduino UNO + Pololu USB AVR Programmer : issues (Read 7969 times) previous topic - next topic
Coding Badly
Sounds like it is working just like mine does.  Try this from the command-line...
[font=Courier New]avrdude -v -v -v -patmega328 -cavrispv2 -P\\.\COM5[/font]
GianfrancoPa
Under AVRDUDE, no?
Gianfranco
Coding Badly
Under AVRDUDE, no?
I don't understand.
GianfrancoPa
I have to launch this command line using AVRDUDE, not Arduino software, isn't it?
Gianfranco
Coding Badly
Yes.  You type the command (or copy-and-paste it) into a "dos prompt" (a command-shell).  The command shell can be started by running "CMD".
You will either have to navigate to the folder containing AVRDUDE or modify the PATH.  These update the PATH on my computer so I can run AVRDUDE...
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\utils\bin
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\bin
set PATH=%PATH%;C:\arduino\arduino-0022\hardware\tools\avr\etc
Replace "C:\Arduino\arduino-0022\" with the Arduino root folder on your computer.
GianfrancoPa
Under AVRDUDE, no?
This line don't functions, I modified it so:
avrdude -v -v -v -patmega328p -cavrispv2 -P\\.\COM5
and I get:
C:\Documents and Settings\Gianfranco>avrdude -v -v -v -patmega328p -cavrispv2 -P
\\.\COM5
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : avrispv2
avrdude: ser_send(): write error: sorry no info avail
Gianfranco
Coding Badly
http://forum.pololu.com/viewtopic.php?t=2398
GianfrancoPa
I'm using windows XP SP3...
I opened a thread on pololu forum: http://forum.pololu.com/viewtopic.php?f=3&t=3722&p=17560#p17560
Gianfranco
GianfrancoPa
I've installed the programmer in a different pc, and it function!!
Gianfranco
MGeo
The post in Reply #4 says that the programmer port is assigned to COM12.  The command line in Reply #15 is directing to COM5.  Avrdude will not be able to find the programmer at COM5.
GianfrancoPa
I've changed com port from 12 to 5
Gianfranco
