Pages: 1 [2]   Go Down
Author Topic: Arduino UNO + Pololu USB AVR Programmer : issues  (Read 1961 times)
Dallas
Online Online
Shannon Member
Sounds like it is working just like mine does.  Try this from the command-line...
avrdude -v -v -v -patmega328 -cavrispv2 -P\\.\COM5
Palermo
Under AVRDUDE, no?
Gianfranco
Dallas
Online Online
Shannon Member
Under AVRDUDE, no?
I don't understand.
Palermo
I have to launch this command line using AVRDUDE, not Arduino software, isn't it?
Gianfranco
Dallas
Online Online
Shannon Member
Yes.  You type the command (or copy-and-paste it) into a "dos prompt" (a command-shell).  The command shell can be started by running "CMD".
You will either have to navigate to the folder containing AVRDUDE or modify the PATH.  These update the PATH on my computer so I can run AVRDUDE...
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\utils\bin
set PATH=%PATH%;C:\Arduino\arduino-0022\hardware\tools\avr\bin
set PATH=%PATH%;C:\arduino\arduino-0022\hardware\tools\avr\etc
Replace "C:\Arduino\arduino-0022\" with the Arduino root folder on your computer.
Palermo
Under AVRDUDE, no?
This line don't functions, I modified it so:
avrdude -v -v -v -patmega328p -cavrispv2 -P\\.\COM5
and I get:
C:\Documents and Settings\Gianfranco>avrdude -v -v -v -patmega328p -cavrispv2 -P
\\.\COM5
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port                    : \\.\COM5
         Using Programmer              : avrispv2
avrdude: ser_send(): write error: sorry no info avail
Gianfranco
Dallas
Online Online
Shannon Member
http://forum.pololu.com/viewtopic.php?t=2398
Palermo
I'm using windows XP SP3...
I opened a thread on pololu forum: http://forum.pololu.com/viewtopic.php?f=3&t=3722&p=17560#p17560
Gianfranco
Palermo
I've installed the programmer in a different pc, and it function!!
Gianfranco
The post in Reply #4 says that the programmer port is assigned to COM12.  The command line in Reply #15 is directing to COM5.  Avrdude will not be able to find the programmer at COM5.
Palermo
I've changed com port from 12 to 5
Gianfranco
Pages: 1 [2]   Go Up
