Topic: POST to HTTPS Server using MKR1000  (Read 929 times) previous topic - next topic
isacarius
Hi all,
I apologize if this is not in the right format, right forum page for this, or I have not included enough information; this is my first time posting to the Arduino forums page. I am trying to use the MKR1000 to send information (POST) to an HTTPS server. Specifically, I am getting temperature data from a TMP35 sensor and sending a name along with that data. I've used Postman and the server is working fine and returning the correct response; in addition, I have updated certificates on the Arduino. I am using the WiFi101 client and the Arduino HTTP client. Every time I run the code, it takes a while to receive a response and gives me a Status code: -2 with no response. My code is shown at the bottom with some parts removed for confidentiality. I understand this is poorly coded as there's been a lot of testing and edits made to get it running; would appreciate any help and explanations assuming basic knowledge. Thanks!
 Reading temperature sensor data and sending to a server
#include <ArduinoHttpClient.h>
#include <WiFi101.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// Wifi Settings ///////
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
const char serverAddress[] = "name of server address";  // server address name (left out for security)
int port = 8080;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverAddress, port);
int status = WL_IDLE_STATUS;
int statusCode = 0;
String response;
 while(!Serial);
 while ( status != WL_CONNECTED) {
   Serial.print("Attempting to connect to Network named: ");
   Serial.println(ssid);                   // print the network name (SSID);
   // Connect to WPA/WPA2 network:
   status = WiFi.begin(ssid, pass);
 // print the SSID of the network you're attached to:
 Serial.print("SSID: ");
 Serial.println(WiFi.SSID());
 // print your WiFi shield's IP address:
 IPAddress ip = WiFi.localIP();
 Serial.print("IP Address: ");
 Serial.println(ip);
 // assemble the path for the POST message:
 float temperature = 0.0;
 float voltage = 0.0;
 float temperature_in_F = 0.0;
 //String postData = "{temp: 0, robotName: Freddy}";
 String contentType = "application/json";
 String robotName = "Freddy";
 // assemble the body of the POST message:
 int sensorValue = analogRead(A0);
 voltage = sensorValue * (3300/1024); // in milliVolt
 temperature = (voltage - 500 ) / 10;
 temperature_in_F = (temperature*(9/5)) + 32;
 //postData = "temp=" + String(round(temperature_in_F)) + "&" + "robotName=" + robotName;
 //postData = "{\"temp\": \"54\",\"robotName\": \"freight71\"}";
 char* postData = "POST (name of application in form /something/something/something/)HTTPS/1.1\r\nHost: nameofhost.io\r\napplication/json\"\r\ncontent-length:198\r\n\t\"{\"temp\": 54,\"robotName\": \"freight71\"}";
 Serial.println(postData);
 Serial.println("making POST request");
 String path = "(name of application in form /something/something/something/)";
 client.post(postData);
 // read the status code and body of the response
 int statusCode = client.responseStatusCode();
 String response = client.responseBody();
 Serial.print("Status code: ");
 Serial.println(statusCode);
 Serial.print("Response: ");
 Serial.println(response);
 Serial.println("Wait ten seconds\n");
 delay(10000);
ballscrewbob
You can remove the WHILE SERIAL section as it is not really needed any more on the MKR series.
That waits for a known USB/COM  connection before doing anything else so would stop some sketches if they were using just WiFi without a physical computer connection.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
