Topic: my program is showing waves till 10khz but I need the waveform of 51.2khz (Read 246 times) previous topic - next topic
deepti06singh
#include "DueTimer.h"
 * Sawtooth waveform generation using timer
 * Wave frequency = wf (Hz)
 * Samples per pulse = wn (num)
 * So tatal samples passed per second to O/P = wf * wn
 * i.e. timer frequncy to write out, tf = wf * wn
uint32_t wf = 52000; // Frequency of 1Hz. for 51.2 kHz use 51200 and so on.
uint32_t wn = 20; // Length of sine in this program
uint32_t tf = wf * wn;
uint32_t wi; // Sample selector index
int currentSample = 0; // Start from null
int interruptHappened = 0; // Interrupt trigger flag
int sine[] = {
    500,655,794,905,976,1000,976,905,794,655,
500,345,206,95,24,0,24,95,206,345
int sine[] = {
    0x7ff, 0x8d5, 0x9a9, 0xa78, 0xb40,
    0xbff, 0xcb2, 0xd59, 0xdf1, 0xe77,
    0xeec, 0xf4d, 0xf9a, 0xfd2, 0xff3,
    0xfff, 0xff3, 0xfd2, 0xf9a, 0xf4d,
    0xeec, 0xe77, 0xdf1, 0xd59, 0xcb2,
    0xbff, 0xb40, 0xa78, 0x9a9, 0x8d5,
    0x7ff, 0x729, 0x655, 0x586, 0x4be,
    0x3ff, 0x34c, 0x2a5, 0x20d, 0x187,
    0x112, 0xb1, 0x64, 0x2c, 0xb,
    0x0, 0xb, 0x2c, 0x64, 0xb1,
    0x112, 0x187, 0x20d, 0x2a5, 0x34c,
    0x3ff, 0x4be, 0x586, 0x655, 0x729
void tHandler() {
  interruptHappened = 1; // Set interrupt flag
  // Obtain curren sample from the waveform's array
  currentSample = sine[wi];
  // Write the sawtooth wave sample to DAC1
  analogWrite(DAC1, currentSample);
  // Increment index to next sample or reset it if at the last sample
  wi = wi + 1;
  if (wi == wn) {
    wi = 0;
  // Can be changed to control phase of the O/P
  wi = 0;
  // Set BAUD rate for Serial stuffs
  Serial.begin(250000);
  // Set DAC1 for output
  pinMode(DAC1, OUTPUT);
  // Set resolution of DAC at 12 bits
  analogWriteResolution(12);
  // Reset analog pin to 0 before starting waveform
  analogWrite(DAC1, 0);
  // Bind TC3 with ISR, set frequency and start it
  Timer3.attachInterrupt(tHandler).setFrequency((double)tf).start();
  if(interruptHappened != 0) {
    // Print saw wave in serial plotter
    Serial.println(currentSample);
    Serial.print(" ");
    interruptHappened = 0; // Reset interrupt flag
