Loading...
Pages: [1]   Go Down
Author Topic: Problem with Reading/Writing to the EEPROM of a MLX90614  (Read 1460 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Hello together,
I am stuck with the following problem and really need help from the community:
I have connected a Melexis MLX90614 Infrared Sensor to the Arduino to get temperature data.
Now i want to reduce the response time of the sensor by changing some values in the EEPROM.
According to this document http://www.melexis.com/Assets/Understanding-MLX90614-on-chip-digital-signal-filters-5272.aspx, I have to change bits 0-2 and 8-10 from a 16 bit column in the EEPROM ConfigRegister1. The other bits should not be changed, so the programm should read the register, make the alterations, then write the register value back, preserving the value in bits 3-7.
I found this sketch that modifies the emission rate of the MLX90614, i think this is very close to what I need:
Code:
/Simple program to read/write to the EEPROM (or read RAM) of the MLX90614 IR Sensor (in my case
//the MLX90614ESF-AAA). Example below erases the emissivity coefficient and then writes E = 1.
//Written be a total beginner, probably includes errors, and can definitely be
//improved on in many ways... /Lo-fi, 2011.
#include <i2cmaster.h>
Serial.println("----------Let's begin!----------");
i2c_init();                             //Initialise i2c bus
PORTC = (1 << PORTC4) | (1 << PORTC5);  //enable pullups
int dev = 0x00; // I use the general address. If I specify the address
                //(0x05<<1), the code doesn't work, don't know why... yet.
unsigned int data_l = 0;
unsigned int data_h = 0;
int pec = 0;
float data_t = 0;
float emissivity = 0;
//READ EEPROM/RAM
Serial.println("*1: Read EEPROM address:");
i2c_start_wait(dev+I2C_WRITE);
i2c_write(0x24);  //0x004 and 0x04 etc reads the same address in the RAM,
                  //add 2(0) for EEPROM, eg. 0x24 (emissivity correction
                  //coefficient in EEPROM).
i2c_rep_start(dev+I2C_READ);
data_l = i2c_readAck(); //Read 1 byte and then send ack
data_h = i2c_readAck(); //Read 1 byte and then send ack
pec = i2c_readNak();
i2c_stop();
Serial.print("Data Low: ");
Serial.println(data_l);
Serial.print("Data High: ");
Serial.println(data_h);
Serial.print("Data combined: ");
data_t = (((data_h) << 8) + data_l);
Serial.println(data_t);
Serial.print("Emissivity: ");
emissivity = ((data_t) / 65535);
Serial.println(emissivity);
delay(5000);
//WRITE TO EEPROM, FIRST: ERASE OLD STUFF
i2c_write(0x24); //Register Address to write to
i2c_write(0x00); //Erase low byte (write 0)
i2c_write(0x00); //Erase high byte (write 0)
i2c_write(0xE8); //Send PEC
i2c_stop();
Serial.println("*2: Erasing old emissivity factor (writing 0).");
delay(5000);
//CHECK IF THE EEPROM VALUE HAS BEEN ERASED
Serial.println("*3: Check if the old emissivity coefficient was erased:");
i2c_write(0x24);  //See above comment.
i2c_stop();
delay(5000);
//WRITE TO EEPROM, THE NEW STUFF!
i2c_write(0xFF); //New emissivity factor, Ef=1
i2c_write(0xCC); //Send PEC
i2c_stop();
Serial.println("*4: Write new E to EEPROM (E = 1.0).");
delay(5000);
Serial.println("----------The process starts over again----------");
delay(5000);
The only thing i know so far is that I have to change i2c_write(0x24);  to i2c_write(0x25); and that I need to send the following 16 Bits to this register:
1;0;0;R;R;R;R;R;1;0;0;R;R;R;R;R
R stands for read, so that the sketch first reads whats the existing value and then uses it.
Can anybody please help me with the adaption of the code ? Thanks a lot in advantage  smiley
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Use 'bitwise AND" and "bitwise OR" operators to clear the fields you want to set and set the values.
Code:
i2c_write(0x24);
unsigned int register = i2c_readAck(); //Read low byte and then send ack
register |= i2c_readAck() << 8; //Read high byte and then send ack
i2c_stop();
// Set the register to: 0b100xxxxx100xxxxx  (where 'x' means 'do not modify)
register &= 0b0001111100011111;  // Clear all bits in the fields to be modified.
register |= 0b1000000010000000;  //Set bits in those fields to 1 where needed
i2c_write(register);
i2c_write(register >> 8);
i2c_stop();
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Code:
i2c_write(0x24);
i2c_stop();
i2c_stop();
Thanks a lot for your work ! Unfortunately, it's not working correctly but I don't know whats the reason...
Heres the full code:
Code:
int dev = 0x5A<<1; // I use the general address. If I specify the address
unsigned int value = 0;
int pec = 0;
i2c_write(0x25);
value = i2c_readAck(); //Read low byte and then send ack
value |= i2c_readAck() << 8; //Read high byte and then send ack
i2c_stop();
wert &= 0b0001111100011111;  // Clear all bits in the fields to be modified.
wert |= 0b1000000010000000;  //Set bits in those fields to 1 where needed
i2c_write(0x25); //Register Address to write to
i2c_write(value);
i2c_write(value >> 8);
i2c_stop();
Anybody finds a mistake ?
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
I still haven't managed it to get the sketch above working :-(
can anybody pls help me ?
Logged
Offline Offline
Newbie
View Profile
I'm trying to build similar scanning IR-camera as your camera. I'm wondering if you have tried reading the chip also with PWM, to test if it would be faster ? As I read from the data-sheets, default output is PWM on the range of -20 - 120 C. As I don't yet have actual chip, I can't verify the code above. But as I get the chip (MLX90614ESF-BCF from Future Electronics), I'll try to reproduce the project and test the response time.
Another speedup would be to highlight the "interesting areas" from the web-cam picture before taking actual temperature-measurements. That way the area that needs to be scanned with the sensor would be much smaller - at least if there are only few interesting areas in the whole picture. That would be useful when scanning for wiring, connectors, IC-chips etc. Lot's of background that could be scanned only with limited resolution / faster and then focus on the most important areas in the picture.
But this all is still theory until they deliver my chip - hopefully soon.
With best regards from Finland,
Henkka
« Last Edit: April 24, 2011, 10:17:19 am by oh6kft » Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
I finally solved the problem, now everything is working:
Code:
Serial.println("This program will change the EEPROM settings of");
Serial.println("your MLX90614-DCI sensor to work best with the");
Serial.println("Cheap-Thermocam. PRESS ANY KEY TO CONTINUE.");
Serial.println("");
Serial.println("Created by Max Ritter - www.cheap-thermocam.tk");
Serial.println("");
while (Serial.available() == 0) {
Serial.println("");
i2c_init();
int dev = 0x00;
int pec = 0;
float data_t = 0;
Serial.println("*1: Erasing old EEPROM settings");
Serial.println("");
Serial.println("Erasing filter settings..");
i2c_write(0x25);
i2c_write(0x83); //Send PEC
//For PEC Calculation have a look at : http://smbus.org/faq/crc8Applet.htm
//In this case the PEC calculates from 250000 (=0x83)
i2c_stop();
delay(5000);
Serial.println("Erasing maximum temperature setting..");
i2c_write(0x20);
i2c_write(0x00);
i2c_write(0x00);
i2c_write(0x43);
i2c_stop();
delay(5000);
Serial.println("Erasing minimum temperature setting..");
i2c_write(0x21);
i2c_write(0x00);
i2c_write(0x00);
i2c_write(0x28);
i2c_stop();
delay(5000);
Serial.println("");
Serial.println("*2: Write new settings to EEPROM");
Serial.println("");
Serial.println("Writing new filter settings..");
i2c_write(0x74); //New filter settings (B374)
i2c_write(0xB3);
i2c_write(0x65); //Send PEC
i2c_stop();
delay(5000);
Serial.println("Writing new maximum temperature setting..");
i2c_write(0x20);
i2c_write(0xFF);
i2c_write(0xFF);
i2c_write(0x67);
i2c_stop();
delay(5000);
Serial.println("Writing new minimum temperature setting..");
i2c_write(0x21);
i2c_write(0x5B);
i2c_write(0x4F);
i2c_write(0x59);
i2c_stop();
Serial.println("");
Serial.println("----------Finish!----------");
The code changes the filter settings of the MLX90614-DCI to the minimum value of 49ms (100% FIR) and extends the standard temperature range from -20 - 120 degree to -70 - 370 °.
@ Henkka:
Great that you also try to build a IR camera. Limiting the scanning range to ínteressting areas will be a possible soon. I will build a portable version of this cheap-thermocam which can be used standalone without any computer and in this step I will include the function. The latest information are always at www.cheap-thermocam.tk  smiley-wink
Logged
Pages: [1]   Go Up
Print
Jump to:
