I've added a new library to the LibraryManager that, in technical terms, is an interface that allows you to define a
run method, similar to Java's
Runnable interface, which will be executed at the specified interval.
In simpler terms, this library allows you to "multi-thread" or have multiple separately executing timed actions.
Here is the
documentation.
How to UseFirst and foremost, your
loop method must call
VariableTimedAction::updateActions constantly. For more timing-intensive applications it is recommended that the call to
updateActions is the only thing in the loop method. It will look like this:
//this static method should really be the only thing called in your loop method to make sure events are updated on time
VariableTimedAction::updateActions();
Next, you can create a timer class like this:
class Counter : public VariableTimedAction {
private:
int count = 0;
//this method will be called at your specified interval
unsigned long run() {
//increase the timer
count++;
//return code of 0 indicates no change to the interval; if the interval must be changed, then return the new interval
return 0;
public:
int getCount() {
return count;
To start this counter you can do this:
Counter secondCounter;
//call the run method every 1000ms (or 1 sec)
secondCounter.start(1000);
To pause/unpause, you can use the
toggleRunning method. To stop the timer, you can use the
stop method. If you use the
stop method, you must use the
start method to begin the counter again. To find out if the timer is running or it is currently paused, use the
isRunning method. You can have as many timers as you like; each of them can be controlled individually.
I've attached the library along with two examples to this post.
Here is the Github page:
https://github.com/amirchev/VariableTimedActionAny feedback is welcome!
