Topic: PPM RC receiver reading (Read 1 time) previous topic - next topic
lebenj
hi,
i'm trying to read only one channel on my RC receiver (Spektrum AR6100).
then move a servo with the servo.h librarie
my problem, is the same a several people: servo jitter....
when use a fixed false input, the servo does not jitter.
so i was playing with a simple sketch to read only the input value.
the result is clear, i don't have a fixed value, it's oscilating, a little, but enough to make jittet to the servo.
i'm sure there is a better way to read the input
my code:
Code: [Select]
    rxRposi = 0;
    for (int i = 0; i < rxRsamples; ++i) {
      rxRpos = pulseIn(pinRchannel, HIGH);
      rxRposi = rxRpos + rxRposi;
            if (rxRpos < rxRmini){
        rxRmini= rxRpos;
       if (rxRpos > rxRmaxi){
        rxRmaxi = rxRpos;
      //delay (2);
    rxRpostotal = rxRposi;
    rxRposave = abs(rxRposi / (rxRsamples));
    //if (rxRposave == 0 || rxRposave < 1000 || rxRposave > 2000) {
     // return;
    //svRpos = map(rxRposave, 1000, 2000, 0, 180);
    //svRpos = constrain (svRpos, 0, 180);
    //rudder.write(svRpos);
    Serial.println("rxRpostotal....rxRposave....rxRsamples....rxRmini...rxRmaxi" );
    Serial.print("....");
    Serial.print(rxRpostotal);
    Serial.print(".........");
    Serial.print(rxRposave);
    Serial.print(rxRsamples);
    Serial.print(rxRmini);
    Serial.println(rxRmaxi);
thanks for your help
MarkT
You could add a little hysteresis to stop the jitter - if the input value varies less than a threshold from the currently used value, ignore the new input.  The threshold might be quite small like 1 or 2.  Alternatively a low-pass filter might be enough (it would lower the frequency of the jitter at expense of slowing the response to changes).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
