Topic: Upload to Uno never finished, "An error occured while uploading the sketch" (Read 383 times) previous topic - next topic
miker00lz
So, this error is a new one to me. It appears to be uploading, the TX/RX LEDs blink for a little bit, then the stop and the IDE just sits there saying "Uploading" and eventually it says "An error occured while uploading the sketch".
I'm assuming it's an issue with my sketch, which is quite large. It uses 98% of the program space, but I don't know why that would break anything. I've tried this on two computers. I've disconnected all shields from the board for the upload, nothing helps.
I'm using 1.8.5, and I've attached the sketch in case anybody has any ideas or pointers here.
Has anyone ever seen this before? Thanks!
EDIT: If you actually try to compile it, you'll need the FemtoCow SPIRAM24 library, and the Adafruit_GFX and Adafruit_TFTLCD libraries.
pert
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
miker00lz
Here's what it gives me. Same result on the other PC I tried.
Code: [Select]
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Mike Chambers\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 3.3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\MIKECH~1\AppData\Local\Temp\arduino_build_258490/apple2.ino.hex"
avrdude: writing flash (31812 bytes):
Writing | ############################################avrdude: stk500_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
miker00lz
I figured it out. My AVR's flash has finally started failing. Fair enough, I've had it for 7 years. I picked up a new Uno and it works fine.
olf2012
There are older versions of the bootloader that have an upload limit of 30kBytes due to a bug in the bootloader code. This may also be the cause. I find it very hard to actually exceed the upload limit of 10,000 writes :-)
https://code.google.com/archive/p/arduino/issues/380
