Topic: My spectrum analyzer is noisy! (Read 948 times) previous topic - next topic
davepl
Jul 04, 2018, 03:31 am Last Edit: Jul 04, 2018, 03:34 am by davepl
I wrote a spectrum analyzer for my ESP32 NodeMCU and it's fast and happy and pretty, but it's not accurate or a pretty as it should be because it is very noisy.
If you play a pure sine tone, you'll get a peak one one bar and then randomness to about half that bar's height on the other bars.  Adjusting my noise floor can help, but doesn't solve it.
I figured the code might be of use to someone, particularly if we can make it work properly, so I'll share it here.  Please take a look at the FFT and comment on what I might be doing wrong!
Thanks,
Dave
Code: [Select]
class Analyzer
  private:
static const int SAMPLES = 512;
static const int SAMPLING_FREQUENCY = 32000; // Hz * 2, so max frequency measured is half the sampling frequency
static const int NOISE_CUTOFF = 1000;
arduinoFFT _FFT;
unsigned int _sampling_period_us;
unsigned long _microseconds;
byte _peak[MAX_BANDS] = { 0 };
double _vReal[SAMPLES];
double _vImaginary[SAMPLES];
unsigned long _newTime;
unsigned long _oldTime;
int dominant_value;
uint8_t _inputPin;
static int * BandCutoffTable(int bandCount)
if (bandCount == 8)
return cutOffs8Band;
if (bandCount == 16)
return cutOffs16Band;
if (bandCount == 32)
return cutOffs32Band;
Serial.println("Error: Bogus bandCount");
int BucketFrequency(int iBucket)
if (iBucket == 0)
return 0;
int iOffset = iBucket - 2;
return iOffset * (SAMPLING_FREQUENCY / 2) / SAMPLES;
  public:
Analyzer(uint8_t inputPin)
_inputPin = inputPin;
_sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
byte * GetBandPeaks()
return _peak;
void SampleAudio(float deltaTime, int bandCount)
for (int i = 0; i < bandCount; i++)
_peak[i] = 0;
float expectedTime = SAMPLES * _sampling_period_us;
unsigned long startTime = micros();
for (int i = 0; i < SAMPLES; i++)
_newTime = micros();
_vReal[i] = analogRead(_inputPin);
_vImaginary[i] = 0;
while ((micros() - _newTime) < _sampling_period_us)
// BUGBUG busy waiting!
Serial.printf("Sampling took %d us and was expedcted to take %d", micros() - startTime, (unsigned long)expectedTime);
int * Bands = BandCutoffTable(bandCount);
_FFT.Windowing(_vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
_FFT.Compute(_vReal, _vImaginary, SAMPLES, FFT_FORWARD);
_FFT.ComplexToMagnitude(_vReal, _vImaginary, SAMPLES);
// Magical noise filter from https://www.youtube.com/watch?v=5RmQJtE61zE
// The Goggles, they do nothing!  So commented out for now.
// for (int i = 2; i < SAMPLES / 2; i++)
// _vReal[i] = sqrt(_vReal[i] * _vReal[i] + _vImaginary[i] * _vImaginary[i]);
double overallPeak = 0.0f;
if (_vReal[i] > overallPeak)
overallPeak = _vReal[i];
float amplitudeScaling = overallPeak / 256.0f; // We want all results to scale down to a byte
if (amplitudeScaling <= 32.0f) // Some reasonable "max" amplifiication for quiet areas
amplitudeScaling = 32.0f;
Serial.printf("Peak: %f, Scaling: %f\n", (float)overallPeak, amplitudeScaling);
if (_vReal[i] > NOISE_CUTOFF)
int freq = BucketFrequency(i);
int iBand = 0;
while (iBand < bandCount)
if (freq < Bands[iBand])
iBand++;
if (iBand > bandCount)
iBand = bandCount;
float scaledValue = _vReal[i] * scalars16Band[iBand] / amplitudeScaling;
byte byteVal = scaledValue > 255 ? 255 : (byte) scaledValue;
if (byteVal > _peak[iBand])
_peak[iBand] = byteVal;
PieterP
You should probably use a logarithmic scale for your display.
Did you use a windowing function? Do you have an anti-aliasing filter?
Your input is real, so an FHT would be much more efficient than an FFT.
Pieter
davepl
Makes sense but no one else seems to apply a log scale, though I can try it!
I do use windowing, but with the defaults, if that matters.
I do not have a good anti-aliasing filter as I've not found one in another spectrum analyzer that works!
PieterP
Audio level indicators usually have a logarithmic scale. (E.g. VU meters and decibel meters.)
davepl
Can someone suggest a function I can apply to the data to convert it from log to linear?
Code: [Select]
_vReal[i] = func(_vReal[i]);
But what is func?  I tried natural log and log2 and log10, both seem to scale WAY too much, so I'm not really sure what I'm looking for!
jremington
#5
Jul 04, 2018, 06:01 pm Last Edit: Jul 04, 2018, 06:02 pm by jremington
Quote
Aliasing leads to what appears to be noise in a spectrum.
To avoid aliasing, you MUST NOT allow signals with frequency higher than (sample frequency)/2 to reach the input.
To test your FFT function, create an ideal data stream with known signals that obey the rules, and offer that as input.
davepl
I really think logarithmic scaling of the display would fix it; a pure sine wave tone, even though a speaker and into the mic, generates a full, single bar at the right frequency.   So in other words, a test tone works.
But you'll still get noise in most cases, and if it were logrithmic I think it'd go away, because the noise is always in smaller amounts.
But let's say my raw data peaks range from 0 to 4095.  To scale those to a 16-segment display, I divide by 256 which of course works, but that's a linear conversion (I do it dynamically and adjust gain and more but that's not relevant here).   Being audio/decibels I assume that like a VU meter, it should be logarithmic.
But how do I map 0-4096 down to 0-15 in a logarithmic fashion?  I tried a quick pass over the data with something akin to:
Sample = log(Sample)
But neither the natural log nor log 10 is really appropriate.  Ideally I'd like to hook it up to a potentiometer and adjust the scaling live for the best visuals using music, but I'm not sure how to do an "arbitrary" logarithmic mapping in C.
Any help on how to make a "variably logrithmic" mapping function that I can connect to a pot would be great!
DVDdoug
This won't help, but...
Quote
Quote
Right, you need an analog filter to filter the signal before it's digitized.
But, aliasing only happens when the signal is above the Nyquist limit (half the sample rate).    You won't get aliasing with a sine wave as long as you're below the Nyquist limit.
...Aliasing isn't always a big deal with a "music display" because the highest frequencies (or supersonic frequencies) in music are generally low-level so the aliases are also low level.   But, if you are making a spectrum analyzer as a measurement instrument an anti-aliasing filter is critical.
DVDdoug
#8
Jul 04, 2018, 07:16 pm Last Edit: Jul 04, 2018, 07:25 pm by DVDdoug
Quote
dB = 20 x log (x/Ref)
If 4096 is your zero-dB reference, dB = 20log(x/4096)
...That is log10.
Quote
The normal way would simply be a "volume control" pot...   That's how just-about everything  in audio works...  You start-out with plenty of signal and then attenuate with a volume control.
But, you can also do it digitally.   Amplification is multiplication.  Multiply by 2 to double the signal  and multiply by 0.5 to cut the signal in half, etc.   After conversion to dB amplification/attenuation is addition/subtraction.  Add 6dB to double the signal and subtract 6dB to cut it in half, etc.     Or, you can use a different dB reference (something other than 4096).
You could  map a pot to change the digital amplification factor or the dB reference, or you can make an automatic sensitivity control...
I've never made a spectrum analyzer but I've made some sound activated lighting effects that work on "loudness".    I save a loudness sample* once per second in a 20-second circular buffer.**   Then depending on the effect I use the peak or the average from the 20-second buffer as my reference or as my threshold.
I have a "VU meter" effect that is NOT a VU meter.   The "top" of the meter is the 20-second peak and the "bottom" of the meter is the 20-second average.   (It's not logarithmic.   It's a biased-linear scale.)  It gives lots of "meter action" with loud or quiet music.
* This is NOT a waveform sample and it's NOT REALLY "loudness".   In my application it's the short-term peak from a peak detector circuit, which is a reasonable approximation of loudness.    (You can't use a peak detector with a spectrum analyzer because there is no audio out of it but you can do something similar digitally.)
** See the Smoothnig Example if you don't know how a circular buffer works.
MarkT
A spectrum analyzer is almost always used in logarithmic mode.
Quote
Yes, most windows are hopeless - what is the default?
Quote
Its a hardware filter you need, nothing to do with the code.
MarkT
Code: [Select]
Sample[i] = scale * log (Sample[i]) + offset ;
davepl
Can you explain the offset?
Speaking of offset, I'm also curious if I need to be removing a DC bias from the analogRead() results?
jremington
#12
Jul 05, 2018, 03:24 am Last Edit: Jul 05, 2018, 03:24 am by jremington
Quote
Nope.
A low pass antialiasing filter will help though.
el_supremo
You should remove the DC bias from analogRead. For 10-bit ADC subtract 512 from each sample. For 12-bit ADC subtract 2048.
Pete
Don't send me technical questions via Private Message.
MarkT
Very simple its an offset.  So the trace can be where you want vertically.  Since this is a logarithmic
value being plotted then only the left most value represents DC.
Remember the output of an FFT is in the frequency domain.
