Topic: Writing password to flash memory on Due (Read 462 times) previous topic - next topic
s_janath
Jul 06, 2018, 08:23 am Last Edit: Jul 06, 2018, 09:06 am by s_janath Reason: add attachment of results
dear friend,
my program is running & not retrieving password from flash, please help
i am using due
s_janath
if i use
 configuration.pass = "chnewpass";
instead of
chnewpass[0]='1';
      chnewpass[1]='2';
      chnewpass[2]='3';
      chnewpass[3]='4';
   configuration.pass = (chnewpass);
it is working but i need to pass it through a variable as it is received from keypad.
thanks in advance
ard_newbie
You didn't use DueFlashStorageStructureExample.ino properly.
In this modified version, the password is retrieved:
Code: [Select]
#include <DueFlashStorage.h>
DueFlashStorage dueFlashStorage;
char chnewpass[5];
struct Configuration {
  char* pass;
Configuration configuration;
  chnewpass[0] = '1';
  chnewpass[1] = '2';
  chnewpass[2] = '3';
  chnewpass[3] = '4';
  chnewpass[4] = '5';
  /* Flash is erased every time new code is uploaded. Write the default configuration to flash if first time */
  // running for the first time?
  uint8_t codeRunningForTheFirstTime = dueFlashStorage.read(0); // flash bytes will be 255 at first run
  Serial.print("codeRunningForTheFirstTime: ");
  if (codeRunningForTheFirstTime) {
    Serial.println("yes");
    /* OK first time running, set defaults */
    // write configuration struct to flash at adress 4
    byte b2[sizeof(Configuration)]; // create byte array to store the struct
    memcpy(b2, &configuration, sizeof(Configuration)); // copy the struct to the byte array
    dueFlashStorage.write(4, b2, sizeof(Configuration)); // write byte array to flash
    // write 0 to address 0 to indicate that it is not the first time running anymore
    dueFlashStorage.write(0, 0);
  else {
    Serial.println("no");
  byte* b = dueFlashStorage.readAddress(4); // byte array which is read from flash at adress 4
  Configuration configurationFromFlash; // create a temporary struct
  memcpy(&configurationFromFlash, b, sizeof(Configuration)); // copy byte array to temporary struct
  Serial.print(" pass: ");
  for (int i = 0; i < 5; i++) {
    Serial.print(configurationFromFlash.pass[i]);
s_janath
 dear friend,
the below code should be run only once so i placed it inside "if (codeRunningForTheFirstTime)" loop
then this not working
  chnewpass[0] = '1';
  chnewpass[1] = '2';
  chnewpass[2] = '3';
  chnewpass[3] = '4';
  chnewpass[4] = '5';
why ?
i cross checked this "Serial.print(configurationFromFlash.pass);"
is just using "configuration.pass = (chnewpass);" and printing
s_janath
#4
Jul 06, 2018, 02:35 pm Last Edit: Jul 06, 2018, 02:39 pm by s_janath
if i use
it is working
but ............
if i place the below code  inside "if (codeRunningForTheFirstTime)" loop
chnewpass[0] = '1';
chnewpass[1] = '2';
chnewpass[2] = '3';
chnewpass[3] = '4';
chnewpass[4] = '5';
why ?
 thanks for your effort Mr. ard_newbie
s_janath
#5
Jul 07, 2018, 06:27 am Last Edit: Jul 07, 2018, 08:25 am by s_janath
new update
after changing my code to the below --
the password is changing to 1234 instead of 4321 after power off /reset
it means password is not stored in flash memory
Code: [Select]
String newpass , flashpass;
 char chnewpass[5];
  char* pass;
 chnewpass[0]='1';
      chnewpass[1]='2';
      chnewpass[2]='3';
      chnewpass[3]='4';
      chnewpass[4]='\0';
  uint8_t codeRunningForTheFirstTime = dueFlashStorage.read(10); // flash bytes will be 255 at first run
    chnewpass[0]='4';
      chnewpass[1]='3';
      chnewpass[2]='2';
      chnewpass[3]='1';
      chnewpass[4]='\0';
    //OK first time running, set defaults
      for(int i = 0; i < 5; i++)
{delay(500);
  Serial.print("chnewpass byte array: " );
Serial.print(i);
Serial.print( " = ");
  Serial.println (chnewpass[i]);}
{delay(500);
  Serial.print("configuration.pass: " );
Serial.print(i);
  Serial.println (configuration.pass[i]);}
   dueFlashStorage.write(10, 0);
  else {
Serial.print(" configurationFromFlash.pass:");
Serial.println(configurationFromFlash.pass);
Serial.print(" pass:");
  flashpass = configurationFromFlash.pass;
Serial.println(flashpass);
//Serial.println(flashpass);
  delay(10000);}
