Topic: Unalbe to store Previous State Node MCU EEPROM , Take a look at MY EEPROM code  (Read 300 times) previous topic - next topic
Ameen33
Guys i am using nodemcu to store the relay states in the EEPROM, the code works for 1st relay ( pin 12 ), but its not working for the 2nd relay. I don't know which part am i going wrong.
Below is my code
 It connects to an MQTT server then:
  - on 0 switches off relay
  - on 1 switches on relay
  - on 2 switches the state of the relay
  - sends 0 on off relay
  - sends 1 on on relay
 It will reconnect to the server if the connection is lost using a blocking
 reconnect function. See the 'mqtt_reconnect_nonblocking' example for how to
 achieve the same result without blocking the main loop.
 The current state is stored in EEPROM and restored on bootup
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Bounce2.h>
#include <EEPROM.h>
#include <WiFiManager.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
const char* ssid = "SSID";
const char* password = "PASS";
const char* mqtt_server = "mqttserver";
#define mqtt_user "id"
#define mqtt_password "pass"
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* outTopic = "Sonoff1out";
const char* inTopic = "Sonoff1in";
int relay_pin = 12;
int relay_pin2 = 4;
int button_pin = 0;
bool relayState = LOW;
// Instantiate a Bounce object :
Bounce debouncer = Bounce();
void setup_wifi() {
   delay(10);
  // We start by connecting to a WiFi network
  WiFiManager wifiManager;
  wifiManager.autoConnect("Grayhats");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload);
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '0') {
    digitalWrite(relay_pin, LOW);   // Turn the LED on (Note that LOW is the voltage level
    Serial.println("relay_pin -> LOW");
    relayState = LOW;
    EEPROM.write(0, relayState);    // Write state to EEPROM
    EEPROM.commit();
  } else if ((char)payload[0] == '1') {
    digitalWrite(relay_pin, HIGH);  // Turn the LED off by making the voltage HIGH
    Serial.println("relay_pin -> HIGH");
    relayState = HIGH;
    EEPROM.commit();
  } else if ((char)payload[0] == '2') {
    relayState = !relayState;
    digitalWrite(relay_pin, relayState);  // Turn the LED off by making the voltage HIGH
    Serial.print("relay_pin -> switched to ");
    Serial.println(relayState);
    EEPROM.commit();
  } else if ((char)payload[0] == '3') {
    digitalWrite(relay_pin2, LOW);  // Turn the LED off by making the voltage HIGH
    Serial.println("relay_pin2 -> LOW");
    relayState = LOW;
    EEPROM.commit();
  } else if ((char)payload[0] == '4') {
    digitalWrite(relay_pin2, HIGH);  // Turn the LED off by making the voltage HIGH
    Serial.println("relay_pin2 -> HIGH");
    relayState = HIGH;
    EEPROM.commit();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("gray01",mqtt_user, mqtt_password)) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish(outTopic, "Sonoff1 booted");
      // ... and resubscribe
      client.subscribe(inTopic);
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      for(int i = 0; i<5000; i++){
        extButton();
        delay(1);
void extButton() {
  debouncer.update();
   // Call code if Bounce fell (transition from HIGH to LOW) :
   if ( debouncer.fell() ) {
     Serial.println("Debouncer fell");
     // Toggle relay state :
     digitalWrite(relay_pin,relayState);
     if (relayState == 1){
      client.publish(outTopic, "1");
     else if (relayState == 0){
      client.publish(outTopic, "0");
     digitalWrite(relay_pin2,relayState);
     if (relayState == 3){
      client.publish(outTopic, "3");
     else if (relayState == 4){
      client.publish(outTopic, "4");
  EEPROM.begin(512);              // Begin eeprom to store on/off state
  pinMode(relay_pin, OUTPUT);     // Initialize the relay pin as an output
  pinMode(button_pin, INPUT);     // Initialize the relay pin as an output
  pinMode(13, OUTPUT);
  relayState = EEPROM.read(0);
  debouncer.attach(button_pin);   // Use the bounce2 library to debounce the built in button
  debouncer.interval(50);         // Input must be low for 50 ms
  digitalWrite(13, LOW);          // Blink to indicate setup
  digitalWrite(13, HIGH);
  pinMode(relay_pin2, OUTPUT);     // Initialize the relay pin as an output
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);          // Blink to indicate setup
  digitalWrite(4, HIGH);
  setup_wifi();                   // Connect to wifi
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  client.loop();
  extButton();
I need to store the  state of 4 relays to nodemcu EEPROM. Please help  out.
