Topic: A4988 PCB (Read 647 times) previous topic - next topic
Francisco-Colli
Jul 07, 2018, 06:08 am Last Edit: Jul 08, 2018, 01:18 am by Francisco-Colli
What do you think about this A4988 PCB Mini Circuit? it connects RESET with SLEEP, GND to GND. Also, it has some terminals for 1A, 1B, 2A, 2B, DIR, STEP, and VDD
Circuit
PCB
FINALLY IT WORKED!! I MAKE A 2 A4988 CIRCUIT
Robin2
There is a good diagram of the connections on the Pololu A4988 web page.
Please make your image visible. See this Simple Image Guide
...R
Stepper Motor Basics
Simple Stepper Code
Two or three hours spent thinking and reading documentation solves most programming problems.
MorganS
I wasn't aware the A4988 came in a through-hole version. Unless you just made a breakout for a breakout?
PCB designs are write-only. Reading them is pretty much impossible. (As opposed to reverse-engineering an example where you have the components to look at too.)
If you want feedback on your circuit, start by showing the schematic.
"The problem is in the code you didn't post."
Francisco-Colli
The circuit is posted!!
jremington
#4
Jul 07, 2018, 07:44 pm Last Edit: Jul 07, 2018, 08:02 pm by jremington
A4988 package:
Robin2
#5
Jul 07, 2018, 07:58 pm Last Edit: Jul 07, 2018, 08:06 pm by Robin2
Considering the low price of an A4988 module I can't see the point of a DIY version.
The OP's circuit has no current sensing resistors and they are an essential part of a stepper motor driver.
Just had a thought ... maybe the OP's PCB is intended to take a Pololu A4988 module and make it easier to connect to?
...R
Francisco-Colli
...R
Yup It`s just made for simplifying the connections
Francisco-Colli
Robin2
Are the PCB traces for motor power capable of carrying the current?
...R
Francisco-Colli
...R
I forgot it, but the motor runs at 24v, i think the PCB traces are power capable of carrying 24v
jremington
The motor current destroys PCB traces, not the voltage.
Francisco-Colli
...R
Motor current is 1.5A
Robin2
Can your PCB traces comfortably carry that much current?
...R
Francisco-Colli
...R
I don`t know, can i test it or something?
Robin2
#14
Jul 12, 2018, 07:41 pm Last Edit: Jul 12, 2018, 07:42 pm by Robin2
What does Google say about the current carrying capability of PCB tracks?
What would you do if you discovered that the tracks are not able to carry the current?
...R
