Topic: getting a sanguino to work (Read 1 time) previous topic - next topic
oldbeeman
hope you will let me ask a question about a sanguino
am trying to make a sanguino to work and am not having much luck.
i d/l the sanguino  files from the sanguino site and put the files in the hardware folder in the arduino folder
the board is set to sanguino
comport is set to 4   that is where the usb cable is connected.
i get the red and blinking green lites on the board when starting.
i tried to run the blink example but when it tries to load it says
binary sketch size: 1002 bytes (of a 63488 bytes maximum)
avrdude: stk500_getsync(): not in sync: resp=)x))
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
what am i doing wrong or what else should i have done.
is there a list for discussion of the sanguino board.
is there a schematic of the serial cable.
and somewhere i saw a list of the correspondence between  arduino and sanguino pins
i really don't want to bug you but
HELP
dave alexander k7da
Mr._Swarf
Dave,
Quick question... Have you installed a bootloader on the Sanguino? The one time I saw an error like that I had somehow managed to munge the bootloader on an ATmega328. Reburn the bootloader and all was well.
I don't know what you have for a programming device but installing a bootloader via the IDE and my USBasp programmer was painless.
M.S.
