Topic: Invalid Device Signature error. Burn Bootloader on ATMEGA328PU using Arduino (Read 338 times) previous topic - next topic
tomk825
I want to run my project on a standalone ATmega328 instead of the Arduino Pro Mini 5V I've been using. I pulled an ATmega328PU of an Arduino Uno R3 I already had and have been following this tutorial to program it using the internal clock (no crystal): https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
I have:
Uploaded the ArduinoISP sketch onto an Uno
Downloaded the breadboard-1-6-x.zip (I am running Arduino 1.8.1) and placed it in a "hardware" folder in my sketchbook folder
Restarted the Arduino software
Chose ATmega328 on breadboard for the Board
Made all of the necessary wiring connections (and quadruple-checked their accuracy)
Set Programmer to 'Arduino as ISP'
When I click Burn Bootloader, I get the following output:
Code: [Select]
Arduino: 1.8.1 (Windows 8.1), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM2 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM2
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.05s
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Error while burning bootloader.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa3
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Thanks in advance!
westfw
Quote
If the chip is from a working Arduino Uno, its fuses will have already been set for the external crystal, and you won't be able to do any programming of the chip in a stand-alone environment unless you have the crystal, or use some mechanism to inject a clock signal.
tomk825
It looks like I'll just be buying some ATmega328 chips that are completely unprogrammed then. Thank you!
