Topic: (Silicone) Multi-Conductor Copper Cable? (Read 753 times) previous topic - next topic
Edgar1
For my Arduino project I need cables with multiple wires.
Some of these wires are for power supply (i.e. maybe 20 or 24AWG) and other wires are for signals (maybe 28 or 30AWG).
I looked in shops and online sites but I just can't find those cables anywhere. Maybe I search with the wrong words (multi conductor cable, multi core, etc) or maybe they just don't exist.
Best case I want "silicone wires" because they are so flexible.
Attached is a picture with a home made solution of two 24AWG silicone wires and three 30AWG silicone wires in clear heat shrink. Is that a good way to do this?
Thanks for any suggestions.
DVDdoug
Silicone might be difficult to find but I got lots of hits when I Googled "multiple conductor cable".  Or, if you're in the U.S. you can try DigiKey or Mouser.
You can get "telephone cable" in 2, 4, or 6 pair.  Phone cable comes solid or stranded and of course you want stranded since you want it to be flexible.     "Cat 5" or "Cat 6" Ethernet cable is 4-pair (8 conductors) and it's super common.
Quote
There's nothing wrong  with that if it works for you.    It's time consuming so you wouldn't want to do that "in production".
larryd
No technical PMs.
The last thing you did is where you should start looking.
larryd
#3
Jul 10, 2018, 07:02 am Last Edit: Jul 10, 2018, 07:09 am by larryd
I make up cabling as seen in this link:
http://forum.arduino.cc/index.php?topic=381469.0
See PDF offered there.
No technical PMs.
Edgar1
@DVDdoug: Thanks for "telephone cable", I knew there must be a word for it...
@larryd: There are many places with silicone wire in lots of sizes and colors. But I din't find multi core cables (i.e. 5*30 AWG silicone wire.
Edgar1
larryd
No technical PMs.
pert
I've also found it difficult to do general searches for specific multi-core wire configurations. There is a convention: {gauge}-{conductor count} or {gauge}/{conductor count} but it's not used universally. It is more common in mains wiring but there it's kind of confusing because the ground wire is not included in the conductor count.
westfw
There are a couple of "standardish" cable types with different-sized conductors.   USB cable, for example will frequently have bigger power leads than signal leads.  (eSATAp and firewire too?)  Or you can use multi-conductor cable with all the same sized leads, and assign multiple leads to each power connection.
outside of existing standards, you're probably looking at custom fabrication and big $$$.
Southpark
#9
Jul 11, 2018, 09:56 am Last Edit: Jul 11, 2018, 09:59 am by Southpark
Nice one Larry. Where did you get the removable pin version of the headers from? I wouldn't mind getting some of those to try out.
Update: found it.... "2.54mm Male+Female Dupont Wire Jumper And Header Connector Housing Kit" - ebay.
Edgar1
I bought this set some time ago.
https://www.banggood.com/320Pcs-Dupont-Connector-Housing-Male-Crimp-Pins-Female-Terminal-Pitch-Jumper-Pin-Header-Kit-p-1091928.html
And this crimp tool:
https://hobbyking.com/en_us/hobbyking-jst-sh-connector-crimping-tool.html
polymorph
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Paul__B
Do the wires really have to be smaller?
5 wire silicone cable for a soldering iron:
https://www.banggood.com/Five-Core-Silicone-Wire-for-T12-HAKKO-936-937-907-Soldering-Station-Handle-Line-p-1153992.html
I think you aced it there!  First post said five wires, that is five wires.  +1!
And a five metre length!  :smiley-cool:
Edgar1
#13
Jul 12, 2018, 04:28 am Last Edit: Jul 12, 2018, 04:30 am by Edgar1
Thanks, I also found one with 5 wires:
https://www.banggood.com/White-Soft-5-Core-Silicone-Wire-Soldering-Station-Handle-Line-for-T12-936-937-907-9501-2028-p-1304421.html
In this case I want to use the cables on my motorcycle which has in some places some very narrow passages. This is why I try to make that cables not bigger than necessary.
A year or two ago I built two racing quads. One of them very small (RTF 84g). At that time I learned to appreciate silicone wires and also very small wires. If a 30AWG wire does the job (just to transfer signals) why use anything bigger?
This is obviously not absolutely necessary but nice to have.
Attached is a picture of the mini quad with 30AWG silicone wires. The jumpers show the real size of this thing.
Southpark
#14
Jul 12, 2018, 04:39 am Last Edit: Jul 12, 2018, 04:40 am by Southpark
Nice that the 5 core silicone is available. Surely, if they can make 5 core, they can make 6 core!! Would be nice for my small brushed 6 wire DC motors hehehe. Tough luck for me unfortunately.
