Loading...
Pages: [1]   Go Down
Author Topic: Arduino chattin' to flash.  (Read 520 times)
Offline Offline
Newbie
View Profile
Hello. I have managed to get flash to talk to my arduino using serproxy. Now I need to get my arduino to talk to flash.
I have tried using the Serial.write(); arduino command to broadcast when a button has been pressed on the arduino. Now I need to get flash to read this command.
How would I go about doing this?
This Is the code I have so far for both arduino and flash.
Arduino:
Code:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    Serial.write("A") ;
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
    Serial.write("B");
Flash As3:
Code:
import flash.net.Socket;
import flash.events.*;
import flash.utils.ByteArray;
var socket:Socket = new Socket("127.0.0.1", 5331);
var socketholder = socket.readUTFBytes(socket.bytesAvailable);
socket.addEventListener( ProgressEvent.SOCKET_DATA, dataReceived );
function dataReceived ( pEvt:ProgressEvent ):void
if (socketholder == "A"){
trace("wehey!");
button.addEventListener(MouseEvent.CLICK, turn_on);
function turn_on(event:MouseEvent):void{
if (socketholder == "B"){
trace("also wehey!");
Thank you in advance for any help which may be given.
Danny.
Logged
Pages: [1]   Go Up
Print
Jump to:
