Topic: about the mq2 / mq7 sensor (Read 6317 times) previous topic - next topic
fakeid
hi, i hope i got the right place asking a question here,
so, recently, i have a school project about arduino, and i want to create a simple gas driven project,
so, i follow this link to connect the mq2 / mq7 gas sensor,
http://nootropicdesign.com/projectlab/2010/09/17/arduino-breathalyzer/
yet, no matter how many times i tried, the readings are so strange and i have no idea of what i could deal with the problem
here is some readings
23
0
0
0
0
1023
1023
1023
0
0
0
0
1023
1023
1023
0
0
0
285
1023
1023
327
0
0
1023
1023
1023
0
0
0
622
1023
anyone could help??
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
fakeid
int sensorValue = 0;
int sensorPin = 9;
  Serial.begin(9600);      // sets the serial port to 9600
  pinMode(sensorPin, INPUT);
  sensorValue = analogRead(sensorPin);     // read analog input pin 9
  Serial.print(sensorValue);  // prints the value read
  Serial.print(" ");      // prints a space between the numbers
  delay(1000);              // wait 100ms for next reading
johnwasser
pinMode(9, INPUT)  will set Digital I/O pin 9 to be a digital input.
analogRead(9) will read Analog Input pin 9 ?!?  Do you have an Arduino that has more than the usual 6 analog input pins (0-5)?!?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
fakeid
thx for reply first,
actually, i have try to connect into analogue A0 at the bottom right of the arduino,
yet, the outcome is also almost the same, strange readings
johnwasser
From the readings it appears that you may have a bad connection somewhere or some bad noise in the input.  When you hook a multimeter between the input pin and ground do you get a nice steady voltage reading?
fakeid
thx again, and i have checked immediately, i have gaineded steady voltage reading, and i have also checked the data sheet, http://www.winsensor.com/english/products/sms/jsq.asp?filename=MQ7.pdf, so, i am sure i am supplying 5.2 - 5.4 voltage to the circuit correctly, and the readings are still not ok ...
btw, is it necessary to pre-heat this sensor? i have found one point in the datasheet saying that it takes 2 days to re-heat the sensor,
so does it mean i have to supply 5 volt to the circuit for 2 days for reasonable readings?
sorry, i have a fairly ok knowledge only, thx for your patience, thxthxthx
robtillaart
Quote
IIRC it is needed for calibration (only once). To use this sensor you have to apply 60sec 5Volts and then 90sec 1.4 Volts. Can be done with PWM. Measure at the end of a 1.4V cycle. So one reading every 2.5 minutes is possible.
This thread may be helpfull - http://arduino.cc/forum/index.php/topic,55780.0.html - Contact cronus as you learn about the same sensor.
Rob Tillaart
fakeid
sorry... i am still clueless of what i could do after i have tried several times...
so, now, how to wiring the sensor to give it a 60sec 5Volts and then 90sec 1.4 Volts?
fakeid
since i don't have the breakout kit.. i don't have TOG Pin from sensor board, but six PINs AHA, BHA............
omg
vhenamae
Hi guys.. anyone knows how to convert the analog input of mq-7 to ppm?
uzz3
Hello all,
I have exact the same problem, and readings as you. Did you managed to make it work? or does anyone has a solution for this?
meccip
Try 10 K Resistor between Analog IN and GND.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
