Topic: Power arduino UNO with 3.3v to 4.0 v (Read 239 times) previous topic - next topic
ditelen
Hello, can i power arduino uno with 3.3 v or 4.0 volts without reduce the MHz. On the board the crystal are 16 MHz. Can arduino run stable with this supply and this frequency ?
sterretje
#1
Jul 11, 2018, 06:19 am Last Edit: Jul 11, 2018, 06:22 am by sterretje
Figure 29-1 in the datasheet of the 328P.
For 3.3V, no.
For 4V, yes.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ditelen
DrAzzy
#3
Jul 12, 2018, 12:50 am Last Edit: Jul 12, 2018, 12:51 am by DrAzzy
That said, people seem to report that the 328p works at 16mhz 3.3v, or at least most units do at room temperature.
However, it is outside spec and may not work reliably or over full temperature range, or with all individual parts.
Note that you would need to put that voltage on the 5v pin, and if the board was plugged into USB, 5v would be applied to that pin, which could damage the power supply and/or board.
I'd use a pro mini and power via vcc pin on 6-pin ftdi header, thus keeping you from plugging it into a potentially 5v serial adapter at the same time as the lower voltage supply. They even make 3.3v pro mini with 8mhz crystal installed...
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
