Topic: Starter Kit Project #15 optocoupler (Read 278 times) previous topic - next topic
StewieStew
I'm trying to gain a better understanding of optocouplers. In my project, I am attempting to use an optocoupler to activate a pushbutton that will power an LED (the LED and pushbutton simulate a separate circuit). Once the Arduino powers on, the LED lights up successfully for three seconds before powering off, and never turning on again regardless of the delay values I input into the program. If anyone can explain what exactly is happening I would greatly appreciate it.
pwillard
You only activate the Optocoupler LED for 15ms and you expect to see it?   Maybe you need to turn on that LED a bit longer... like 2 seconds...
Note to all: USE DRAWINGS not photos of your "air wires".  The pictures are almost useless as a reader will run out of patience trying to figure out what your intentions are.
groundFungus
I don't see a current limit resistor for the LED.
Paul__B
Hmmm.  You don't suppose that is because you have it connected to pin 1 of the Arduino instead of pin 2?  :smiley-eek:  This is the Tx pin, activated while Optiboot waits to see if you want to program it, then shuts off until you activate the serial interface.  :smiley-roll:
I do.  :smiley-lol:
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Currently it is hard to see the orientation of the Opto and LED.
Just as you have a current limit resistor on the input to the opto, you need a current limit resistor in series with the LED.
As has been pointed out the delay(15), is a delay of 15ms, try delay(1000), it will turn the LED on for 1000ms or 1Second.
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
StewieStew
Yup this fixed the issue, *Slaps face
[/quote]
I do.  :smiley-lol:
