Topic: ERREUR TÉLÉVERSEMENT  (Read 234 times) previous topic - next topic
APOSETREP
bonsoir voici mon problème compilation OK lors de la fin du téléversement message d'erreur je vous met que ce qui est mi en orange
Code: [Select]
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp:550:42: warning: unused parameter 'i' [-Wunused-parameter]
 void Adafruit_GFX::invertDisplay(boolean i) {
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp: In member function 'boolean Adafruit_GFX_Button::contains(int16_t, int16_t)':
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp:607:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
    if ((x < (_x - _w/2)) || (x > (_x + _w/2))) return false;
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp:607:32: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp:608:11: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
    if ((y < (_y - _h)) || (y > (_y + _h/2))) return false;
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp:608:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega1280 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX" "-IC:\Program Files\Arduino\libraries\Touch-Screen" "-IC:\Program Files\Arduino\libraries\DS1307new" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp" -o "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp.o"
In file included from C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:30:0:
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\pin_magic.h:306:33: warning: backslash and newline separated by space
   #define read8inline(result) { \
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:819:0: warning: "read8" redefined
   #define read8(x) x=read8fn()
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\pin_magic.h:207:0: note: this is the location of the previous definition
   #define read8             read8inline
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::begin(uint16_t)':
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\pin_magic.h:425:21: warning: large integer implicitly truncated to unsigned type [-Woverflow]
   hi = (d) >> 8; lo = (d); CD_DATA   ; write8(hi); write8(lo); }
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\pin_magic.h:211:29: note: in expansion of macro 'writeRegister16inline'
   #define writeRegister16   writeRegister16inline
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:294:5: note: in expansion of macro 'writeRegister16'
     writeRegister16(ILI9341_VCOMCONTROL1, 0x2B2B);
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:285:14: warning: unused variable 'a' [-Wunused-variable]
     uint16_t a, d;
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:285:17: warning: unused variable 'd' [-Wunused-variable]
     uint16_t a, d;
APOSETREP
puis un peu plus bas dans la liste
Code: [Select]
Archiving built core (caching) in: C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_cache_308748\core\core_arduino_avr_mega_cpu_atmega1280_5638c217b04eda8279099c4937887265.a
Linking everything together...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega1280  -o "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.elf" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\sketch\Horloge_tft_DS3231.ino.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\SPFD5408_Adafruit_GFX\glcdfont.c.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_GFX.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\Touch-Screen\TouchScreen.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\DS1307new\DS1307new.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\Wire\Wire.cpp.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995\libraries\Wire\utility\twi.c.o" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/core\core.a" "-LC:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995" -lm
C:\Users\Alexis-Anais\Downloads\Horloge_TFT DS3231\Horloge_tft_DS3231\Horloge_tft_DS3231.ino: In function 'setup':
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:813:5: warning: 't' may be used uninitialized in this function [-Wmaybe-uninitialized]
     writeRegister8(ILI9341_MADCTL, t ); // MADCTL
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:797:14: note: 't' was declared here
     uint16_t t;
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:790:4: warning: 't' may be used uninitialized in this function [-Wmaybe-uninitialized]
C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX\SPFD5408_Adafruit_TFTLCD.cpp:774:13: note: 't' was declared here
    uint16_t t;
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.elf" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.eep"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.elf" "C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.hex"
Plusieurs bibliothèque trouvées pour "Wire.h"
Utilisé : C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Non utilisé : C:\Program Files\Arduino\libraries\Wire
Utilisation de la bibliothèque SPFD5408_Adafruit_GFX prise dans le dossier : C:\Program Files\Arduino\libraries\SPFD5408_Adafruit_GFX (legacy)
Utilisation de la bibliothèque Touch-Screen prise dans le dossier : C:\Program Files\Arduino\libraries\Touch-Screen (legacy)
Utilisation de la bibliothèque DS1307new prise dans le dossier : C:\Program Files\Arduino\libraries\DS1307new (legacy)
Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Le croquis utilise 36432 octets (28%) de l'espace de stockage de programmes. Le maximum est de 126976 octets.
Les variables globales utilisent 889 octets (10%) de mémoire dynamique, ce qui laisse 7303 octets pour les variables locales. Le maximum est de 8192 octets.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1280 -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\ALEXIS~1\AppData\Local\Temp\arduino_build_6995/Horloge_tft_DS3231.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7b
avrdude done.  Thank you.
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
qu'est ce qui se passe ??
lesept
C'est un warning, pas une erreur de compilation, ça n'empêche pas le programme de se charger et de s'exécuter.
Le compilateur te dit ce qui ne va pas :
Code: [Select]
comparison between signed and unsigned integer expressionsLa condition de ton if compare des int et des unsigned int, ce qui risque de provoquer des erreurs lors de l'évaluation de la condition.
Pour ne plus avoir cet avertissement, choisis un type de variable commun à celles de ta condition : sit int soit unsigned int. Si tu veux en savoir plus sur les types : ici et ici
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
APOSETREP
lorsque j'envois simplement sa :
Code: [Select]
message erreur :
Code: [Select]
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x41
Code: [Select]
         Using Port                    : COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x93
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x93
fdufnews
Vérifier le câble USB, le type de carte sélectionné, le port COM utilisé.
APOSETREP
j'utilise une carte arduino mega 2560 (chinoise) avec le pilote usb-serial-ch340, le câble usb est ok, je suis sur le bon port com
je refait un test avec une carte uno neuve (toujours chinoise)
APOSETREP
#6
Jul 11, 2018, 08:20 pm Last Edit: Jul 11, 2018, 08:22 pm by APOSETREP
toujours pareil
je pense a un problème au niveau du fichier avrdude
APOSETREP
problème résolu je ne sais pas comment j'ai simplement desinstaller et reinstaller le log
