Topic: Serialport with C# (Read 225 times) previous topic - next topic
Xamik
I have a C# Code
Code: [Select]
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.IO;
using System.Collections;
using System.IO.Ports;
namespace CaKey
    class Program
        static SerialPort _serialPort;
        static void Main(string[] args)
            _serialPort = new SerialPort();
            _serialPort.PortName = "COM7";//Set your board COM
            _serialPort.BaudRate = 9600;
            _serialPort.Open();
            string wort;
            int index;
            int indexBuchstabe;
            int indexEingabe;
            int score;
            int highscore=0;
            bool ende;
            string eingabe;
            Random random;
            StreamReader objReader = new StreamReader(@"E:\Schule\LBK\Projektwoche\german.txt");
            string stringLinie = "";
            ArrayList Wort = new ArrayList();
            while (stringLinie != null)
                stringLinie = objReader.ReadLine();
                if (stringLinie != null)
                    Wort.Add(stringLinie);
            objReader.Close();
            do
                Console.Clear();
                score = 0;
                ende = false;
                indexBuchstabe = 0;
                index = 0;
                ConsoleKeyInfo info;
                indexEingabe = 0;
                do
                    do
                        random = new Random();
                        wort = Convert.ToString(Wort[random.Next(11)]);
                        char[] buchstabe = wort.ToCharArray();
                        index = 0;
                        indexBuchstabe = 0;
                        indexEingabe = 0;
                        eingabe = "";
                        do
                            Console.Clear();
                            Console.Write("Bitte schreiben Sie das Wort " + "\"" + wort + "\":\t" + eingabe);
                            info = Console.ReadKey(true);
                            if (info.KeyChar == buchstabe[indexBuchstabe])
                                index++;
                                indexBuchstabe++;
                                index = 200;
                            if (index != 200)
                                eingabe = eingabe.Insert(indexEingabe, Convert.ToString(info.KeyChar));
                                indexEingabe++;
                            if (indexEingabe > wort.Length)
                                index = 200;
                        } while (index < wort.Length && info.Key != ConsoleKey.Enter && info.Key != ConsoleKey.Escape);
                        if (index != 200)
                            score++;
                    } while (info.Key != ConsoleKey.Enter && info.Key != ConsoleKey.Escape && index != 200 && score != 1940588);
                    ende = true;
                } while (ende != true);
                if (score > highscore)
                    highscore = score;
                if (score == 1940588)
                    Console.Clear();
                    Console.WriteLine("Herzlichen Glückwunsch!");
                    Console.WriteLine("Sie haben das Spiel durchgespielt und haben somit den Highscore geknackt.");
                    Console.WriteLine("Ihr Score war:\t" + score);
                    Console.WriteLine("\n\n");
                    Console.WriteLine("Ihr Highscore ist:\t" + highscore);
                    Console.WriteLine("Möchsten Sie erneut spielen? true or false");
                    ende = Convert.ToBoolean(Console.ReadLine());
                else if (info.Key != ConsoleKey.Enter && info.Key != ConsoleKey.Escape)
                    Console.Clear();
                    Console.WriteLine("Sie haben leider einen Fehler gemacht.");
                    Console.Clear();
                    Console.WriteLine("Vielen Dank für's mitspielen.");
            } while (ende == true);
and an "Arduino Uno" Code
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
String wort;
  wort=Serial.read();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(wort);
  Serial.flush();
  lcd.setCursor(0,1);
  lcd.print("Score:");
  lcd.print(score);
  if (score==1940588)
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Nice!");
    lcd.setCursor(0,1);
    lcd.print("New Highscore!");
    delay(2000);
    lcd.clear();
    lcd.setCursor(0,1);
    lcd.print("Try again?");
    else if (infoKey!=false)
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("Failure");
      lcd.setCursor(0,1);
      lcd.print(score);
      delay(2000);
      lcd.clear();
      lcd.setCursor(0,1);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Thanks for playing!");
        lcd.setCursor(0,1);
        lcd.print(score);
        delay(2000);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Highscore");
        lcd.print(highscore);
        lcd.setCursor(0,1);
I dont know how to tell the Arduino that he should read the variables word, score and highscore. Can someone telll me?:)
Thanks for your help
PaulS
Code: [Select]
String wort;
  wort=Serial.read();
Serial.read() returns an int, NOT a string, and certainly NOT a String.
Your C# app never actually writes to the serial port, so there will never be anything for the Arduino to read.
A clue, perhaps: http://forum.arduino.cc/index.php?topic=396450.0
