Topic: [SOLVED] Servomotor jerks (Read 257 times) previous topic - next topic
iacoposk8
Jul 11, 2018, 08:29 pm Last Edit: Jul 13, 2018, 07:58 pm by iacoposk8
Hello everyone! I'm testing with servomotors (mg996r).
I used this code but when I run it the servomotor jumps for a minute (see the this video: https://drive.google.com/open?id=1y83XvZb10X7m79iMCFHbqaGK0Rr9gdnH) and then starts working correctly, how do I solve it?
Code: [Select]
#include <Servo.h>
Servo myservo;
int servo_speed = 15;
int moveTO(Servo servo, int degree){
  int pos = servo.read();
  if(pos == degree){
    return pos;
  if(pos < degree){
    for(; pos < degree; pos += 1)
      servo.write(pos);
      delay(servo_speed);
    for(; pos >= degree; pos -= 1)
      myservo.write(pos);
      delay(servo_speed);
  return pos;
  myservo.attach(9);
  moveTO(myservo, 76);
  moveTO(myservo, 152);
  moveTO(myservo, 0);
FredScuttle
When you attach a servo it goes to 90 degrees by default, if you want a different start position, say 15, you can specify it before attaching, do this in setup():
Code: [Select]
servo.write(15);
servo.attach(9);
Awww! Who needs an instruction manual to use a simple chain sa......
groundFungus
#2
Jul 13, 2018, 03:09 pm Last Edit: Jul 13, 2018, 03:09 pm by groundFungus
Code: [Select]
Do you know that the servo.read() function does not return the actual position of the servo, but the last position that was sent to the servo with servo.write()?
iacoposk8
Perfect! thanks, works with 93!
